What do I need to lower my 08 civic hybrid?
Old Oct 31, 2012
itsDUHstin's Avatar
itsDUHstin is an unknown quantity at this point
I wanted to know if I needed anything special to lower my 08 civic hybrid?
Old Oct 31, 2012
Re: What do I need to lower my 08 civic hybrid?
well the springs should be made for the hybrid, otherwise the heavy battery pack will cause major sagging in the rear. you need lowering springs, upgrade shocks for lowered cars, and alignment kit at the least. eventually you will need better sway links and front control arm bushings. it will wear on the suspension more overall as well, so keep an eye out for unusual noises or sloppy steering that may indicate a loose or broken suspension part.
Old Nov 1, 2012
double your battery packs so you can have double the milegae before recharging and a lowered stance with less stability.
stop crapping everyday and you could lower even more one side of the car. some difficulties in clicking the belts might arise.
tylerginevan
Apr 27, 2015 12:29 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
inarschenk
South
Apr 18, 2015 04:29 PM
dooner24
Apr 14, 2015 07:51 PM
EvilTwin
Nov 8, 2001 12:17 PM
