High & Low Beam Flasher
Old Aug 21, 2013
Rakesh Mahendra's Avatar
Rakesh Mahendra
Rakesh Mahendra is an unknown quantity at this point
Can some one please tell me how to flash the beam during day time driving without switching on the head lights of my Civic? It does not seem to be possible without keeping the lights on.
Old Aug 22, 2013
Re: High & Low Beam Flasher
Pull the turn signal lever toward you.
Old Aug 25, 2013
Rakesh Mahendra
Thanks but it does not work till you switch on the lights. I am concerned about day time driving when the head lights are not on. This a serious defect which HONDA needs to set right by a recall as it is a serious hazard. When a fast moving car is approaching fro the opposite side during day time, there is no time to switch on the head lights and flash the beam as a warning.
Old Aug 25, 2013
CraigW's Avatar
What year ? US Model ??
That feature goes way back in time.
Old Aug 25, 2013
Assuming the India market version of the car was equipped the same as the rest of the world...... Kinda sounds like Rakesh owns a car that's broken.
That doesn't make it Hondas responsibility in any way, shape, or form.
Old Aug 25, 2013
From an 08 owners manual:
High Beams
Push the lever
forward until you hear a click. The
high beam indicator will come on
(see page 61). Pull the lever back to
return to the low beams.
To flash the high beams, pull the
lever back lightly, then release it.
The high beams will stay on as long
as you hold the lever back.
Old Aug 25, 2013
My '02 civic and my gf's '08 civic high beam flash works properly. A recall would only happen if it was a defect in a large percentage of that model produced.
Your combination switch is probably broken, as ezone implied.
stryder12
Jun 30, 2015 08:33 PM
ericaagarcia
Jun 11, 2015 11:29 AM
tmc66
Jun 9, 2015 04:07 PM
speedracersong
Jan 27, 2002 06:28 PM
civiccowboy
Jan 20, 2002 06:05 AM
