Sponsored by:
Sponsored by: CARiD
harness install (help)
Old Jun 13, 2003
blue03civic's Avatar
Pro Skater
Question harness install (help)
im getting the weapon-r racing harnesses and im not 100% sure about how to install them? does neone have directions and aslo i saw on the sight a bolt in kit and a snap in kit? do i need this and which one should i get any help is appreciated...Thanx
Old Jun 13, 2003
CarbonFly's Avatar
search next time
http://www.7thgencivic.com/forums/sh...threadid=90795
BTW, Weapon R is a generic company and their belts are NOT street legal/DOT approved.
Old Jun 13, 2003
cdmx's Avatar
dont think he cares..I honestly wouldn't.....i like your harnesses fly but i wouldn't want them buckled to the rear seat
Old Jun 14, 2003
CarbonFly's Avatar
I would care, when your LIFE is what hangs in the balance here. It is not the time to cheap out on products. Safety is a must.
Then where do you plan on bolting them? It's the only safe place to attach them. Even in the instructions for the belts it tells you that it's the only place that it should be done. When I have passengers who sit in the rear all I have to do is use the quick release buckle and then use the stock belts.
Old Jun 14, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
you just got L3ASED by FlyRiceRacer!!!
Injen
Old Jun 17, 2003
cdmx's Avatar
Where do all the rest of the harnesses bolt to??
Id assume to the back bottom of the seat. This is probably safer than the stock seat belts.
Old Jun 17, 2003
cdmx's Avatar
except mabye id have to rig a seatbelt across the lap...or mabye wear both seat belts stock and the harness
Old Jun 17, 2003
CarbonFly's Avatar
Did you not read my DIY when I installed the belts? It clearly tells you.
Look at the rear seatbelts. Follow the straps all the way down into under the seat. The racing harness strap is put on the SAME bolt at the rear stock belt.
Old Jun 17, 2003
R3DL1N3's Avatar
shouldnt this go in tech stuff
BootyDo
Jun 21, 2016 03:45 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
