Sponsored by:
Sponsored by: CARiD
What is this supposed to be??
Old Apr 7, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Question What is this supposed to be??
I was browsing through ebay and saw this post. Can someone explain the reason why this guy claims that a resistor will improve engine performance and therefore give more HP? I find it hard to believe.
Link
Old Apr 7, 2003
flotsamm's Avatar
I vaguely remember reading about this before... it has something to do with changing the values of one of the sensors that tricks the ECU into thinking the A/F is running richer, so it leans out the fuel delivery. I think thats how it works.. I'm sure someone will correct me if I'm wrong.
Old Apr 7, 2003
CarbonFly's Avatar
It's a load of crap is what it is.
Old Apr 7, 2003
Bartkat's Avatar
I think it goes in the ATS wire. The ATS works on a temp vs resistance curve. If you put in the resistor, it makes the ECU think your air temp is lower, so the ECU will adjust as if you are running cooler air. There is some merit to the idea. There have also been many threads on this inthe past.
Old Apr 7, 2003
spookini's Avatar
spookini is an unknown quantity at this point
So is that the scoop? I causes you to run leaner? But since the engine temp isn't REALLY lower, won't that over time damange your engine....detonation and all that stuff?
Old Apr 7, 2003
Bartkat's Avatar
If anything it would run richer. With a cold engine the ruel setting needs to be rich.
I'm not gonna say whether it will hurt your engine or not, because it isn't something I would do. However, there are other devices on the market that fool your ECU into allowing the engine to do things it wouldn't normally do.
Old Apr 7, 2003
Bartkat's Avatar
If your ECU didn't control the air fuel mix, then a SRI or CAI would make your engine run lean also. That's one reason why you don't get much out of an intake on certain cars.
Running lean will cause running hot which can burn your valves.
Old Apr 7, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
Have fun messing up your car to who ever gets it
I'll let everyone in on a little know secret for those who don't already know, the reason products don't catch on is because THEY ARE CRAP!!!
and if you want a resistor, 5 cents @ radioshack
Old Apr 8, 2003
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
I think it is totally BS. $6 for an increase of 20 hp.
Old Apr 8, 2003
R3DL1N3's Avatar
of course, half the **** that comes off of ebay is crap.
Old Apr 8, 2003
Bartkat's Avatar
What exactly resistor would you use to get, say a 20 degree F lower reading to the ECU?
Old Apr 8, 2003
Dr5D's Avatar
like 2001civ said - resistor, 5¢
ThatGuy913
Sep 28, 2015 05:35 PM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
stank
Sep 16, 2015 07:40 AM
Dawit Melese
Sep 11, 2015 08:25 PM
