Sponsored by:
Sponsored by: CARiD
Shift Boot....please help
Old Feb 3, 2003
emmc's Avatar
Venezuelan Member
emmc is an unknown quantity at this point
i just recently bought a type R shift **** and the shift boot is kind of loose.... is there any kind of shift boot that works with the type r ??
i have no idea about shift ***** and boots and that stuff...
Old Feb 3, 2003
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
where is the shift boot loose at? Up at the top by the ****?
Old Feb 3, 2003
TeLLy's Avatar
Yes, it's an Acura EL
I have the stock boot (type R off ebay soon, I'm too ghetto), and the OBX Type-R-style ****. The boot kept falling down and exposing the shift lever, so I just wrapped some elastic on there and crammed the stock boot collar on top of it. It hasn't moved in months, but I anticipate the same problem you are having when I get a new boot. Just get a rubber grommet onto the lever, underneath the metal ring on the top of the boot and that should hold it up fine.
Old Feb 3, 2003
mullinad's Avatar
mullinad is on a distinguished road
I had the exact same problem that you had with the type r **** no longer than a coupe of days ago. What I did, which was suggested in various searches - I wont preach - is that you take electrical tape and wrap it around the shifter pole where you want the boot to stop at. For me it was almost right under the nut that came aong with the shifter. you want the tape to be just as big as the shift boots opening so it will fit snug. Worked for me. electric tape at radio shack - 69 cents..
If you have anymore questions. PM me.
adam
Old Feb 3, 2003
Snakes's Avatar
Snakes is an unknown quantity at this point
another way to solve this problem is to take apart your center console, to get to the inside of the shift boot. then cut the zip-tie holding the plastic ring (that was originally connected to the shift ****) onto the boot. this will make the boot even more loose at the top, but the ring isn't there to weigh it down. if this doesn't satisfy your needs yet, you can just use another zip-tie (without the silver ring) to secure the boot neck to the top of the shift lever. IMO, this gives it a clean look, as opposed to having a loose silver ring.
Old Feb 3, 2003
Snakes's Avatar
and to answer your original question, there is no aftermarket shift boots available for our cars (except for those carbon fiber ones on ebay, but i'd stick with the stock shift boot). if you are going for that type-r shifter look, you can add red stitching to the boot (easier to do if you take apart the center console). i added red stitching to mine and made a matching leather e-brake boot because i plan to add black leather interior w/red stitching to my car in the near future. trust me, looks good. here's a link to how to do it:
shift boot DIY
Old Feb 3, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
No aftermarket shift boots huh? Gee... I've got a MOMO boot in my car and that's an aftermarket product. Any universal boot will fit if you trace and cut the tabs that are on the bottom of the stock boot onto the new one. Some of the universals have velcro tops to they can be used with any **** and others screw in to the threads for the **** finisher on the bottom of the shift ****. I also know this for sure... the MOMO Performance boot can be used with any Honda Factory **** because the threaded ring for the Momo ***** can also be used to lock the clips on the bottom of the Honda *****.
Old Feb 3, 2003
emmc's Avatar
Venezuelan Member
problem solved!!
i put some tape like some u guys said...
thanks for your help...
Old Feb 3, 2003
Snakes's Avatar
Quote
[hr]Originally posted by: Boilermaker1
No aftermarket shift boots huh? Gee... I've got a MOMO boot in my car and that's an aftermarket product. Any universal boot will fit if you trace and cut the tabs that are on the bottom of the stock boot onto the new one. Some of the universals have velcro tops to they can be used with any **** and others screw in to the threads for the **** finisher on the bottom of the shift ****. I also know this for sure... the MOMO Performance boot can be used with any Honda Factory **** because the threaded ring for the Momo ***** can also be used to lock the clips on the bottom of the Honda *****.[hr]
don't get your panties in a twist, man. all i meant was that there is no direct replacement and you would have to do some type of modification to any universal type boot to make it fit at the bottom (which you said). and that's the fact, jack.
Old Apr 27, 2003
outdrsmn80's Avatar
outdrsmn80 is an unknown quantity at this point
Yeah, I took a zip-tie and inverted the top of the boot. It looks real clean now.
Old Apr 27, 2003
outdrsmn80's Avatar
Here is a pic
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Jrosa
Sep 14, 2015 08:24 PM
