Sponsored by:
Sponsored by: CARiD
any problems with indiglo gauges??
Old Feb 2, 2003
angjc3's Avatar
angjc3 is an unknown quantity at this point
just wondering, if anyone has had any problems with their indiglo gauges, I just bought some and wanted to know if anyone is dissapointed with them.
DIY
and yes I've done a search, some of the info on the searches are old, just wanted to see as of right now if anyone has has problems.
Old Feb 2, 2003
Gizmo's Avatar
Gizmo is an unknown quantity at this point
I had mine installed the other day and they are a little flaky. From what I have seen once the gauges work correctly there great (and right now mine look good) but I have to turn my inside lights with the *** all the way down and play with it to get them to come on. Its just annoying, but once I get it taken apart and make sure everything is plugged in right im sure everything will be fine.
Old Feb 2, 2003
Kairi's Avatar
Kairi is an unknown quantity at this point
I have them, they are fine. No problems and I installed them myself with the instructions from the web site. Install them right and you have zero problems. Also make sure to glue those suckers down properly with something good and thin otherwise you'll get sticky speedo. Last piece of advise: there are little parts to the gauges that connect bottom left/right to middle left/right that kind of block some of the signal lights (i.e. parking brake, safety belt, etc) make sure to cut those pieces away so they dont dim your original lights and look whack. very clean in the end. enjou
-kairi
Old Feb 3, 2003
kenji4861's Avatar
kenji4861 is an unknown quantity at this point
Quote
[hr]Originally posted by: Kairi
-kairi[hr]
Used the online DIY.. was scared to take it apart at first, but now that I look back.. it was easy as hell.
I'm a very picky guy, and I like it!
Old Feb 3, 2003
Jodster's Avatar
Post Whore General
I had to take mine off last week because they burned out. I had them for about 10 months. All I can tell you is make sure you don't get a cheap pair like I did. They don't last.
Old Feb 3, 2003
I got the blue/green ones from autodynamic. It came with a nice switch and ****, and I like the EL blue color. So far no problems, but if there are more than a few accessories on at a time they tend to flicker (not enough power from crappy alternator).
Old Feb 3, 2003
SatansEnemy's Avatar
SatansEnemy is an unknown quantity at this point
someone might wanna make a note of this somewhere. i noticed that there are little plastic rings around the needles, below the pointer, that i think all they do is keep light from showing everywhere, well when you put the guages in you might move one(pop it outta place) and that was causing my speedo to stick. i took two exacto knives and just popped them back in place, now mine work perfectnot showing light from around the needles or nothing i love mine, bought a cheap pair so they might not last, but maybe they will. i love the look
later,
"WorM"
edit: i didnt see this info in the diy, it might be in there but i didnt see it.
i had thought that i had screwed my cluster up, but found this prob.
Old Feb 3, 2003
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
Some of the gauges cover the lights, I believe its the APC ones, but mine didn't have those. Just hold it up over you gauges first to see if there covering any thing. I got the same ones as kenji4861. They have been great and no problems. I don't have any light coming through at all
tylerginevan
Apr 27, 2015 12:29 PM
LX2slow
Dec 20, 2001 08:33 AM
manicEL
Dec 10, 2001 06:33 PM
AJ
Dec 4, 2001 09:08 PM
GreenVenom
Nov 13, 2001 03:35 PM
