Sponsored by:
Sponsored by: CARiD
FIBERGLASS?????
Old Jan 23, 2003
1983's Avatar
1983 is an unknown quantity at this point
FIBERGLASS?????
HEY GUYS I WAS THINKIN OF BUYING A BODY KIT BUT IT IS MADE IN FIBERGLASS, made of 6-layer hand-laid fiberglass....
IS THAT ANY GOOD OR IT WILL CRAK VERY EASY ESPACIALY IF ITS EXPOSED TO COLD DEGREE (CANADA)
THANX
Old Jan 23, 2003
Vinh's Avatar
if you wanna jenny craig your car.......fiberglass is the way to go.....
but for bodykits in fiberglass....not recommended....
when u drive on roads....the rocks will leave permanent marks...even more noticeable on dark color cars.....
just go wit ABS material or someting to that matter...
Old Jan 23, 2003
Grey's Avatar
DIY King
Yeah, fiberglass is very light. That's one advantage. It does crack if you run into something and it tends to fit a little less than perfect. Urethane, or ABS, or any other plastic is superior IMO. Although bodykit manufacturer's don't really care about weight when they make urehtane kits, so they tend to be overly heavy. My front bumper (Tsunami) is 1/4" thick urethane throughout with no structural supports. Very flexible and able to withstand many hits, but it's kinda heavy. I will be lightening mine with chemicals that eat through urethane. I'll block off a triangular support structure and eat through 1/8" of it on the inside. That should make it a little lighter.
Old Jan 23, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
ok listen. u buy a kit for 700 u paint it for 400 that = 1100 now i dont know about you but i wouldnt want to spend that much just to have it cracked and replaced. buy urethane or abs plastic kits. and make sure u use "FLEX" in the paint so the paint wont crack when the kit flexes. fiberglass is cheaper than urethane but once u crack it or break it its gonna cost a whole lot more than the urethane kit would cost in the first place. plus if u drive the car daily u deff want the strength of urethane.
Old Jan 23, 2003
XxSoVeReiGNxX's Avatar
Quote
[hr]Originally posted by: Grey
Yeah, fiberglass is very light. That's one advantage. It does crack if you run into something and it tends to fit a little less than perfect. Urethane, or ABS, or any other plastic is superior IMO. Although bodykit manufacturer's don't really care about weight when they make urehtane kits, so they tend to be overly heavy. My front bumper (Tsunami) is 1/4" thick urethane throughout with no structural supports. Very flexible and able to withstand many hits, but it's kinda heavy. I will be lightening mine with chemicals that eat through urethane. I'll block off a triangular support structure and eat through 1/8" of it on the inside. That should make it a little lighter. [hr]
Old Jan 23, 2003
1983's Avatar
THANX FOR UR COMMENTS GUYS BUT I HEARD THAT HAND-LAID FIBERGLASS DOESNT CRAK EASY UNLIKE THE ONE BUILT WITH A KIND OF GUN!!!
ANY COMMENTS ON THAT????
Old Jan 24, 2003
ACE646's Avatar
ACE646 is an unknown quantity at this point
It depends on how you drive, as long as you are really careful its no problem look at my car almost the whole thing is fiberglass but I am so careful its not even funny just watch out for other SOBs.
General DIY
Sep 25, 2015 08:02 PM
KronikScott
Jun 9, 2015 08:00 PM
durkinz
Jul 3, 2002 04:33 PM
2cute
May 20, 2002 02:14 AM
