Sponsored by:
Sponsored by: CARiD
easy install for lx headers?
Old Oct 3, 2002
vanny2k1's Avatar
vanny2k1 is an unknown quantity at this point
i'm new to this site so if this question has already been asked sorry.. but is there a header that is specifically made for an lx coupe 5-speed taht doesn't require a lot of custom stuff. just one that i could bolt up in like an hr?
Old Oct 3, 2002
dacivic's Avatar
dacivic is an unknown quantity at this point
You should use the search button. Anyway there is no header that fit perfectly into a lx. You need a piggy back computer some some modification to make it work.
Old Oct 3, 2002
zetaR's Avatar
zetaR is an unknown quantity at this point
Quote
[hr]Originally posted by: dacivic
You should use the search button. Anyway there is no header that fit perfectly into a lx. You need a piggy back computer some some modification to make it work.[hr]
That's not true. The kamikaze header was made for the lx/dx. It does fit perfectly. Kamikaze just doesn't provide the necessary gaskets and hardware. You also don't need a piggy back computer. Unless you're referring to an O2 simulator ($45), which is needed in order to get your check engine light to go off. Not exactly what I would refer to as a piggy back computer.
Old Oct 3, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Isn't there a way to extens the sensor into the hole, or is the problem that there isn't a hole for the second sensor?
Old Oct 3, 2002
zetaR's Avatar
You just have to splice into the O2 sensors and then lengthen them.
Old Oct 3, 2002
iamboo's Avatar
Retired - SoCal FI Mod
the o2 sensor is connected to a wiring harness... buy the wire harness extension and you can move the o2 sensor farther down...
kamikaze is a good header that'll fit... from what i've heard, hp has redesigned the headers and they will fit... i dunno... but don't take my word for it.. SEARCH homie
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
