Sponsored by:
Sponsored by: CARiD
RSX shift knob cured rough shifting
Old Sep 20, 2002
impetigo's Avatar
impetigo is an unknown quantity at this point
RSX shift **** cured rough shifting
just picked up my new oem RSX shift **** at the acura dealer, and like everyone has said, it is great. it fits perfectly, is considerably shorter, and looks alot better. the main benefit for me though is that the 1st to 2nd gear shift is smooth now, whereas before it was often a little rough (could feel the gears [IMG]i/expressions/face-icon-small-sad.gif[/IMG] ) at times. not to mention it's quicker too. everyone should get one, it's more than worth the $31.70 i spent on it.
Old Sep 20, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
Hey nice brief review
thanks for the [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 20, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
i would think about buying that except that since i hold my hands at 9 and 3 all the time, my hands gets sweaty sometimes. i cup-palm shift so i dont want my sweat to make my hand slide off the ****.
Old Sep 20, 2002
4g63turbo's Avatar
4g63turbo is an unknown quantity at this point
if you need a shorter shifter to actually drive a manual...then buy an obx short shifter...or take a hacksaw to it...rap with blue electrical tape(makes it go faster) then acquire gold marker to inscribe acura signia...either that or learn how to drive a stick...just my two cents...
Old Sep 20, 2002
impetigo's Avatar
Quote
[hr]Originally posted by: 4g63turbo
if you need a shorter shifter to actually drive a manual...then buy an obx short shifter...or take a hacksaw to it...rap with blue electrical tape(makes it go faster) then acquire gold marker to inscribe acura signia...either that or learn how to drive a stick...just my two cents...[hr]
nice job, that was both insightful and clever. keep up the good work.
Old Sep 20, 2002
Quote
most people dont know correct shifting...that is why people use short shifters.
Old Sep 20, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Quote
[hr]Originally posted by: LikeWEEEEEEEEEE
Quote
most people dont know correct shifting...that is why people use short shifters.[hr]
WHAAAAAT?? Ok someone's been taking bong hits again[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
The reason (at least it should be) why you would want a short shifter is to reduce the actual distance of each shift throw. The best short shifters allow adjustment of fore-aft and sideways throws.
No offense meant, I just found this kinda funny.
Old Sep 20, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
What I'm not understanding is how a SHIFT **** made your gear transactions smoother. That sounds like a bunch of retardation to me.
Old Sep 20, 2002
Bartkat's Avatar
"What I'm not understanding is how a SHIFT **** made your gear transactions smoother. That sounds like a bunch of retardation to me."
Likely you weren't paying attention. Go back and read that first post again. Try to concentrate.
Old Sep 21, 2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
thats cool if it helped your shifting skills too
Old Sep 21, 2002
CapYoda's Avatar
Escaped Convict
shifting FEEL.
**** helps in it.
I got the Neuspeed adapter for the shifting FEEL.. not the shorter distance.. all those short shifters, I dont think they can shorten it much...
its so much smoother in stock form, it feels like butter! but the neuspeed works good if u grease it up too...
I duno, I think most people should get it for the feel.. not for the fact that it reduce the throws, because u can only do so much to the shifter aseembly and shorten the pivot point... the real bottleneck is in the way the actual cable shifter is setup...
I may take out the Neuspeed one day, and go back to stock. Its sooo smooth. man. I think its time to grease up the Neuspeed some more though.
Old Sep 21, 2002
4g63turbo's Avatar
if you honestly think that a short shifter is going to make you faster at all...then two things...first: grab towards the bottom of the shifter and it will act like a short shifter and will only cost you about 1 calorie to move your hand...second: if you really want to go faster in gears CHANGE THE GEAR RATIO...just my two cents..
Old Sep 22, 2002
Quote
if you honestly think that a short shifter is going to make you faster at all...then two things...first: grab towards the bottom of the shifter and it will act like a short shifter and will only cost you about 1 calorie to move your hand...second: if you really want to go faster in gears CHANGE THE GEAR RATIO...just my two cents..[hr]
oh so true...
Quote
[hr]Originally posted by: Silver2k1Dood
Quote
Quote
No offense meant, I just found this kinda funny.[hr]
never grip the shifter in road cars. i learned that a while ago and changed my ways. you never rap your hand around the shift ****. hell you keep your fingers pretty straight actually.
this gives the speed of a short shifter along with the smooth transition. and with a stock "high" shift ****, your arm has to travel less to get to the shifter.
Tyler93
Mar 20, 2016 09:03 PM
danace99
Oct 17, 2015 02:51 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
Jrosa
Sep 14, 2015 08:24 PM
tommycanada
Sep 5, 2015 04:59 PM
