Sponsored by:
Sponsored by: CARiD
installation of cam gear?
Old Sep 16, 2002
nongv's Avatar
nongv is an unknown quantity at this point
has anyone installed the aem cam gear yet? i am looking on buying a cam gear and is wondering if the installation is hard or not?
Old Sep 16, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
i know there's a couple peeps who have them, i don't think anyone has DIY'd it though, i believe you have to take the valve cover off and all that fun stuff, which is a pain.
Old Sep 16, 2002
JAKE's Avatar
JAKE is an unknown quantity at this point
let me tell it is very time consuming. it took me and another guy about 5 hours to install it and tune it up where u need it. u can sort of tell a difference but i took the cover off the cam gear and it can be seen so. Ill try to find something for ya to look at or a DIY. lata bro
JAKE
Old Sep 16, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I installed the cam gear its not that hard. First un hook the ignition coils and pull them out. I took my spark plugs out too but I dont think you have to. I just wanted to check them. Then unscrew the actual valve cover and pull it off. Unbolt the timing cover. Pull the timing cover off. unbolt the old gear. I made a mark on the belt and on the gear so I knew where to line the new gear up. The hardest part was getting the belt back on the gear, you really gotta put some *** into it. After that just put everthing back together. make sure to connect that sensor back below the gear if you unhooked it!!! Its pretty easy, just make sure you have the right tools and a lot of different sockets because some places are pretty tight to get to. If you search the forums for cam gear, i've got several topics I talked about the gear. I don't know if its worth it or not. I can't tell much of a difference it I retard or adavance it. Hey Jake, where do you have your gear set to?
Old Sep 16, 2002
nongv's Avatar
do i make the mark on the old cam or the new one? if it is on the new cam how will i be able to mark the belt along with the cam?
Old Sep 17, 2002
IDQcivic's Avatar
I made a mark on the belt and on a tooth of the gear, then i put the old gear and new gear side by side and marked the new gear with the mark in the same spot, then i lined up the mark on the new gear with the mark on the belt, make sense?
Old Sep 18, 2002
slowciv's Avatar
slowciv is an unknown quantity at this point
I istalled the cam gear on my car and advanced it 6 degrees. I didnt feel any real HP but it did make the car run easier. The gear made dramatic changes because It didn't take so long to get through each gear. It made each gear faster to get through. I thought it helped quite a bit.
159
Jul 5, 2015 09:54 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
blacklud
Apr 13, 2015 06:15 PM
thesushiboy
Apr 12, 2015 07:40 PM
CivicPunker17
Nov 21, 2001 06:14 PM
