Sponsored by:
Sponsored by: CARiD
Adding in a Shock sensor to factory alarm???
Old Aug 28, 2002
Luda's Avatar
Luda is an unknown quantity at this point
Does anyone know if you can add a shock sensor to the factory alarm. I could only assume yes if you are able to find out if the shock sensor is a power or ground trigger device then find the according wire on the alarm unit. I have accessibility to the alarm under the dash. If someone has a wiring schematic of the alarm I could testing it then.
Just looking for some advice b4 I spend over $100 to install a $20 shock sensor!
Thanks guys!
Old Aug 28, 2002
Mbow's Avatar
Did you have the oem alarm added to your civic? Everyone thinks they have an oem alarm when all they really have is keyless entry.
Old Aug 28, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
First thing to do is to see if you actually have the alarm like Mbow said. Lock your doors with the remote. Then walk over and open your trunk with the key. If your horn starts honking and your lights start flashing, you have an alarm option. If nothing happens, then all you have is keyless entry.
You can easily buy the alarm option for 120 plus installation. But all it has is door triggers and a trunk trigger. It also adds a flashing LED to ward off the ignorant.
With the OEM alarm and the factory engine kill, our cars are somewhat protected from being stolen (except by tow trucks, had to add that), but other than opening up the doors or trunk, nothing is done to prevent theft of contents.
Hence I guess the question of adding a shock/motion other sensor.
The easiest way would be to buy a common shock sensor and wire it to mimic the trunk grounding input via a relay. I am currently in the process of adding this and I will try to add a DIY, but like Mbow said, check to even see if you have the alarm first.
Peace
Old Aug 28, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Quote
[hr]Originally posted by: EvilDave666
the OEM alarm isnt really an alarm. its a keyless entry w/ a panic button. if u bought it, as did i, you got jacked. i am getting my clifford installed soon.[hr]
same.... KARR sucks
edit: P.O.S. remote control has a 2ft range.
Old Aug 28, 2002
slikor's Avatar
slikor is an unknown quantity at this point
hmm...i thought the OEM alarms did have a shock sensor?? thats what i've read anyway.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Aug 28, 2002
MIT's Avatar
MIT
MIT is an unknown quantity at this point
OEM alarm sux, no shock sensor....nothing secure just automatic lock door for ya. what everyone think about ~~Viper 300ESP, i want to replace to this alarm in couple week. any opinion?
thanks
mrohitredd
May 28, 2015 10:03 AM
Thees1
Apr 14, 2015 08:23 AM
GPMarzan
Jan 5, 2002 02:30 PM
ImmortalEX
Jan 2, 2002 08:45 AM
rhyno
Nov 27, 2001 10:07 PM
