Sponsored by:
Sponsored by: CARiD
backup lights
Old Aug 2, 2002
Dr5D's Avatar
backup lights
I did a search on this and they all said different stuff.
What bulbs can i put in so the backup lights are blue???
some said the 194/168s work, but i think that would be too small. isnt there an actual replacement bulb i can buy? it dosent seem that this should be so comlicated.
Old Aug 2, 2002
CivicPro01's Avatar
CivicPro01 is an unknown quantity at this point
hey does anybody know if there are strobe like size 194?? Thanks and the reverse lights are 194.
Old Aug 2, 2002
Dr5D's Avatar
are you sure???
i heard that those stick strobes fit in the parking light spot perfectly, but i havent tryed it.
Old Aug 3, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
isnt it illegal for back up lights to be anything but white? same withe brake lights..dont they HAVE to be red?
Old Aug 3, 2002
Standish's Avatar
Standish is an unknown quantity at this point
I work @ pepboys and the back up bulb # is 921
Old Aug 3, 2002
skc's Avatar
skc
skc is an unknown quantity at this point
i'm using eurolight 194 bulb for my back up lights.
it fits perfect for my coupe.
do u have sedan or coupe?
Old Aug 3, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Quote
[hr]Originally posted by: Standish
I work @ pepboys and the back up bulb # is 921[hr]
THE BACKUP LIGHTS ARE NOT 921!!!!!!!!!!!!!
You can use the 194/168 bulb but it will be too dim... these are the ones you want:
Click on me
they have the same base as the 194/168 bulb but get bigger at the top....... also they have a higher wattage than the 194/168 bulb, but they don't go over factory wattage
Old Aug 3, 2002
snoopbag's Avatar
snoopbag is an unknown quantity at this point
Yeah they are 194 I used the 4 bulb LED in mine they kick a$$ and are super bright I got them from autodynamic for $11
Old Aug 3, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
they are the same size as the dome lights and the lights between your turn signals and your main headlight, i replaced mine with blue ones-
Old Aug 3, 2002
injencivic's Avatar
red to the rear is legal in my city/state law jurisdictions, check your local dept. of transportation for laws, but more then likely red is fine! i have red license plate lights on mine
Old Aug 3, 2002
Dr5D's Avatar
--hefe-- isnt the picture you put there a 921? i was at walmart last night and i saw some like that that were 921, but they were not blue of course
and i dont think it should be too big a worry how legal it is for your backup light color, how often would a cop see you back up anyways???
Old Aug 3, 2002
Tarik's Avatar
Tarik is an unknown quantity at this point
Quote
[hr]Originally posted by: Dr5D
some said the 194/168s work, but i think that would be too small. isnt there an actual replacement bulb i can buy? it dosent seem that this should be so comlicated.[hr]
194 bulb is not for your back up light, 194 is the license plate light
Old Aug 3, 2002
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
Quote
[hr]Originally posted by: CivicPro01
hey does anybody know if there are strobe like size 194?? Thanks and the reverse lights are 194.[hr]
talk to topfuel, he has some strobe tubes in his back up lights, he wired them to a switch somewhere, he can tell you what to get and where to go.
Old Aug 4, 2002
Hefe's Avatar
Quote
and i dont think it should be too big a worry how legal it is for your backup light color, how often would a cop see you back up anyways???[hr]
If they looked just like that them get them.... if you want plain ol lights...... as long as they hane the 194/168 base
My reverse lights are "hyperwhite"
Old Aug 5, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
Quote
[hr]Originally posted by: Hefe
Quote
[hr]
mine are 921's. thats what the stock bulb said when i pulled it out. i got a 2k1 lx.
Old Aug 5, 2002
Hefe's Avatar
Ok.. I was wrong.... THEY ARE 921!!!!!!
roverben
Jan 21, 2019 05:16 PM
wankers
Jan 20, 2019 06:44 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
