Sponsored by:
Sponsored by: CARiD
Precise Handling With 2025 Civic Godspeed Mono-SS Coilovers
Old Mar 3, 2025
carid's Avatar
Former Sponsor
carid is a jewel in the roughcarid is a jewel in the roughcarid is a jewel in the rough
The 2022-2025 Civic is undoubtedly one of the most fun-to-drive small sedans. Masterfully engineered by Honda, it offers agile handling and a well-balanced ride, no matter your driving style or needs. However, if you're like us and can't settle for stock, Godspeed Project, a leading manufacturer of high-quality suspension products, has introduced the Mono-SS™ Front and Rear Coilover Kit. Designed to be a streetable race-built coilover, this kit provides ideal performance even under the most demanding conditions.
Each component of this single-adjustable coilover suspension kit is engineered using state-of-the-art computer simulations and tested to meet some of the strictest industry standards. The Mono-SS Coilover Kit is equipped with a lightweight aluminum lower mount, T7075 forged aluminum and carbon steel brackets, and a monotube damper made from a durable, seamless 52mm carbon steel tube, featuring a performance-grade internal piston for unmatched damper response. The cold-bent springs, constructed from high-strength SAE9252 steel, deliver the perfect balance between dynamic performance and cushioned ride comfort.
The standout feature of the Mono-SS Coilover Kit is its 16 levels of damper adjustability, allowing you to fine-tune the suspension to match your exact driving preferences.
Godspeed Project® - Mono-SS™ Front and Rear Coilover Kit
Includes:
  • (2) Front Coilovers;
  • (2) Rear Coilovers(1) Tool Kit;
Specifications:
  • Front Coil Sping Tall 180 mm;
  • Rear Coil Spring Tall 180 mm;
  • Front Coil Spring I.D. 62 mm;
  • Rear Coil Spring I.D. 62 mm;
  • Front Coil Spring Rate 6 kg/mm (336 lbs/in);
  • Rear Coil Spring Rate 6 kg/mm (336 lbs/in);
  • Shock Absorber Internal Design Monotube;
  • Shock Absorber Type Gas Charged;
  • Shock Absorber Adjustment Type Single Adjustment;
  • Shock Absorber Levels of Damping 16 Levels;
  • Shock Absorber Reservoir Without External Reservoir;
  • Front Shock Absorber Camber Plate Yes;
  • Rear Shock Absorber Camber Plate No;
Whether you're looking for a softer ride for daily driving or a firmer setup for aggressive cornering, the MonoSS offers unparalleled flexibility, making it perfect for both street use and track performance.
Old Mar 3, 2025
carid's Avatar
Former Sponsor
Re: Precise Handling With 2025 Civic Godspeed Mono-SS Coilovers
Do you have any current suspension upgrades or modifications? Would you like a kit that works seamlessly with other performance mods?
Learn more about the Godspeed Project and find more upgrades suitable for your 2025 Civic at CARiD.[
Old Aug 4, 2025
johnsonjame's Avatar
johnsonjame is an unknown quantity at this point
Includes:
Specifications:
I’ve been running the Godspeed Mono-SS coilovers on my 2025 Civic for a few weeks now, and they’re honestly a solid upgrade for the price. The 16 levels of damping adjustment give you a lot of flexibility I've dialed them down for daily driving and stiffened them up when hitting some twisty roads on weekends.
Installation was pretty straightforward if you have basic tools and some patience. The ride is definitely firmer than stock, but not harsh at all once you fine-tune the settings. The aluminum lower mounts are a nice touch too lightweight but sturdy.
For anyone considering them: they’re not as track-focused as something like KW V3s or BC Racing BRs, but for daily/spirited driving, they’re perfect. Plus, the adjustability really makes them worth it for a daily-driver that occasionally sees aggressive cornering.
Erf_Em2
15
Mar 23, 2016 04:54 PM
Bonnanz
Jun 5, 2010 06:57 PM
CivicRage
26
May 19, 2010 04:58 PM
dirtySAMURAI
Feb 17, 2004 02:22 PM
artychris
Jan 26, 2002 04:20 PM
