Sponsored by:
Sponsored by: CARiD
Head gasket by brand
Old Jun 15, 2015
Allecr3's Avatar
Allecr3 is an unknown quantity at this point
Doing a head gasket job this weekend on my 03 ex, curious as to what brand of head gasket is quality product. Any help is very much appreciated.
Old Jun 15, 2015
Re: Head gasket by brand
I use factory parts, no problems here.
Old Jun 16, 2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
My 03 1.7 is no race car, but id like to put the strongest head gasket out there!
Is there a Heavy Duty gasket brand and what brands should we avoid??
thanks
Old Jun 21, 2015
rallyeredem0's Avatar
rallyeredem0 is an unknown quantity at this point
stick with oem honda parts
Old Jun 22, 2015
Wild Cranker's Avatar
Wild Cranker is an unknown quantity at this point
Ya know... I JUST bought a FelPro PermaTorque MLS gasket for my 1995 D15Z1 about a half hour ago. (I could throw up a pic but you all know what it looks like.) Bought it for $30, new... Put it in my truck, came home, got on Net.. saw this thread.
Freaky.
*I decided to go woth that one because it was, in fact, a Multi-Layer Steel gasket.
I saw a Cometic gasket on EBay at also said Multi-Layer Steel, but it was like $65 and.. if it is Multi-Layer Steel then it's good enough for me. And should be a ONE TIME JOB on my engine...........
Amd heard good things about Victor Reinz gaskets...
Old Jun 22, 2015
Are you familiar with Neons at all?
Reinz was the OE supplier for those head gaskets, roughly 1995~00.
Google 'neon head gasket problems'
Old Jun 22, 2015
Not only did I not know that, but it casts doubt on what I learned from a shadetree mechanic that worked on my truck.
This is the gasket I bought, I actually got mine $5 cheaper with a coupon
Amazon.com: Fel-Pro 9915PT  Head Gasket: Automotive Amazon.com: Fel-Pro 9915PT Head Gasket: Automotive
It was indicated to me a Multi-Layer Steel gasket, with its MLS designation; Therefore, I bought it. I almost went with a Cometic MLS one, but, the main feature I sought was.. not to be redundant, but, MLS. FelPro PermaTorque MLS.
It has been said that is my mating surfaces are exactly straight and very clean and torque is perfect that it will work wonderfully.
New bolts, yes?
Old Jun 22, 2015
New bolts, yes?
Yours uses standard bolts, not TTY bolts. Reuse your head bolts unless they are corroded or something super unusual.
On the newer engines that use the TTY type, Honda would print measurement specs to determine if they need to be replaced or can be reused.
If you can find TTY bolts for your engine, they would go well with MLS gasket.
HTH
Old Jun 23, 2015
I personally would have spent the extra $8 for Honda OEM parts, but that's just me.
Old Jun 23, 2015
HTH
Everything you tell me is something useful. I would like to sponsor you for God mode.
More updates on the other thread. Today was a good day.
Old Jun 24, 2015
jdmspec's Avatar
jdmspec is an unknown quantity at this point
Factory oem honda is the only way to go!
Old Jun 24, 2015
Is it Multi-Layer Steel?
Nothing wrong with OEM, but sometimes parts are made to correct shortcomings in OEM design. My Blazer's fuel injectors are a case-in-point of that. Nobody replaces an S-10 spider injector assembly with OEM...
Old Jun 24, 2015
You'll get to find out when you get your head removed!
IIRC I think your 95 and earlier is composite.
Old Jan 9, 2016
g_force58's Avatar
g_force58 is an unknown quantity at this point
I agree with ezone on the gasket. As a previous owner of a neon I know all too well what he is talking about when he addresses the Victor Reinz gasket problem. Instead of dealing with it anymore I Bought a 2012 Civic.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
01civyv3
Jun 2, 2015 05:21 AM
zaboomafoozarg
May 30, 2015 09:21 AM
HondaHomer
May 14, 2015 12:24 PM
hokiedad4
Apr 30, 2015 07:18 AM
