Sponsored by:
Sponsored by: CARiD
Looking for a part
Old Nov 1, 2012
usvpn's Avatar
usvpn is an unknown quantity at this point
Looking for a part
Hi,
I am looking for a part for my Civic Sedan 2009 LX 4DR which I don't know its name in English and its part number!
The picture is attached...
Anybody can help me please?
Old Nov 1, 2012
GolNat's Avatar
Prelude Owner
Re: Looking for a part
That is your front sway arm end link. Also referred to as front end link. There are 2 one on each end of your sway bar.
Old Nov 1, 2012
#14 or 15, for right or left .
You probably should obtain a set of new nuts also, just to be safe.
http://www.hondaautomotiveparts.com/...tcgry5=KNUCKLE
Left and right of any car are always determined as you sit in the drivers seat facing forward.
HTH
Old Nov 1, 2012
usvpn's Avatar
This is in Knuckle category? I cannot find it @
http://www.hondapartsnow.com/Page_Pr...geName=Knuckle
Old Nov 1, 2012
Your link has the same picture I just posted.
Old Nov 1, 2012
And #18 is the bushings you asked about in the other thread.
Old Nov 1, 2012
usvpn's Avatar
hey buddy, you link does not open for me!
so if the picture is the same, which number is this part?
Old Nov 1, 2012
You are in a different country, sites may be blocked.....
My link didn't work for you...
Ok then, this is YOUR link: http://www.hondapartsnow.com/Page_Pr...geName=Knuckle
And the pic from your link:
14 51320-SNA-A02 LINK, R. FR. STABILIZER $18.57 $13.46
15 51321-SNA-A02 LINK, L. FR. STABILIZER $18.57 $13.46
You should need two of each of these nuts if you do both of the links (one of each per link):
21 90002-S10-000 NUT, FLANGE (10MM) $2.57 $1.86
26 90212-SA5-003 NUT, SELF-LOCK (10MM) $0.55 $0.40
And the compliance bushing
18 51391-SNA-305 BUSH, FR. COMPLIANCE $16.50 $11.96
You may need to use a proxy server to get around site blocks in your country.
HTH
Old Nov 2, 2012
usvpn's Avatar
Number 21 & 26 should also be changed?!
Old Nov 2, 2012
I sometimes have to CUT the nuts (or the links) off in order to remove the links. Easiest to already have new parts before you discover you need them.
Old Nov 2, 2012
mattandchris's Avatar
mattandchris is an unknown quantity at this point
excuse me, I'm not trying to start a new thread....other posters on this site have suggested to replace these end links with ones made by MOOG.
What exactly does MOOG parts have over OEM end links and is it just personal preference?.....................mattandchris
Old Nov 2, 2012
revr63ed7's Avatar
revr63ed7 is an unknown quantity at this point
nothing, nothing beats factory parts. I have replaced quite a few moog parts under warranty for premature failure. You can buy parts from the aftermarket if you know your brands. What i mean is the brand that honda uses as a supplier. This makes it the exact same part your car came with.
Example: many seals and gaskets sold in the usa under the name Stone, if you look closely at the package you will see the true name "ishino". Honda uses ishino for many items. There are many other types of parts you can get like this as well.
Old Nov 2, 2012
How'd you figure that out?
If a factory part can last 100,000-200,000 miles or more, while many aftermarket parts don't last 30,000, does that make it any kind of bargain at all?
Old Nov 2, 2012
revr63ed7's Avatar
I've been studying honda oe suppliers for years and in fact as YOU should notice when looking at the factory parts lists many times it says ishino or atsugi or bando or yamada....on and on. Not everything is that easy, sometimes the symbol tells who actually made it but the honda name is on it.
Wipe off the seals you take out and look close, it will say nt or ishino and have the dimensions like 8x32x54. Some stuff is obvious like bando belts and denso stuff.
Old Nov 2, 2012
Oh.
I don't really pay much attention because I don't have to find aftermarket stuff for Hondas right now LOL.
Yes I know the belts, plugs, and O2 sensors but that's kinda obvious, the name is stamped all over.
In the times that we have to call out for parts, I have zero control over what is sent or used.
mohawkboom
67
Aug 25, 2015 12:28 AM
Tim1959
Jun 3, 2015 08:15 PM
juror
May 26, 2015 06:35 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
