Sponsored by:
Sponsored by: CARiD
Engine Replacement
Old Jun 10, 2012
hasanikhleif's Avatar
hasanikhleif is an unknown quantity at this point
Unhappy Engine Replacement
Hello all,
im Hasan from Jordan, im new in this forum, and it's an honor to me to join you in this forum,
i bought a honda civic 2003 hybrid 2 days ago, and i feel like the engine is not powerful enough because of the bad and mountain roads in my country,
my question is if i can replace the engine of my car with a honda civic 2006 hybrid engine, is it compatible ?? do anyone advice me to replace it if it's doable ??
thank you in advance
regards
Old Jun 10, 2012
Re: Engine Replacement
first off, why did you buy an hybrid then?... the battery weighs a lot...
second, 2006 uses the R-series engine, 2003 uses the D-series not even sure how much differences are in there. electrics harness, ecu, battery compatibility, etc, etc.
if there are dealers that allow you to test drive cars, better off trying to drive a non-hybrid and see if there are differences. (not sure how things are in jordan...)
Oh, yeah, you are on parts and products forum (which are for reviewing products...) - not many do come in here, so few would even see your post...
Old Jun 10, 2012
thank you
it was my first post on this forum and im not used to join forums
thanks
Old Jun 10, 2012
The battery and electronics behind the back seat weigh less than a passenger. I'd guess about 20-25kg for the battery.
OP should return the car and pick something that does what he wants.
A car that gets great fuel mileage isn't going to have a ton of power, and vise-versa.
Old Jun 10, 2012
laithmajed91's Avatar
laithmajed91 is an unknown quantity at this point
hello Hassan am from jordan too ! and trust me 1.3 L just dont cut it , i got a 2005 LX sedan , i swapped in a D17A2 ( 1.7 L ) and i sometimes feel its under powered
best thing to do try and trade in your car with a full gasoline automatic , or go with a 2008 civic depends on your budget , because the swap you are talking about dosent come cheap here .
Old Jun 10, 2012
looks like you got more responses good luck
most seem to recommend changing the car instead...
Old Jun 10, 2012
Unless he has more dollars than sense.
Old Jun 10, 2012
you can get an upgraded battery pack that will give you more electrical assist going up hills, and take extra weight out of the car, but thats about it. the newer hybrids arent much better in the power department. the hybrids are meant to be used in the city and thats where you get the best mileage as well. for highway driving a regular gas car would be just fine. and for mountains, a civic shouldnt even be considered unless you like redlining in 3rd the whole way up and get 10mpg.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
smmahan
Apr 15, 2015 08:17 PM
thesushiboy
Apr 12, 2015 02:54 AM
