Sponsored by:
Sponsored by: CARiD
front Passenger side door will not open
Old Mar 16, 2011
rayaman2's Avatar
rayaman2 is an unknown quantity at this point
Hey guys. I have a problem. I have a 1997 honda civic that my sister gave to me. The car has several problems but one problem i seem to cant find the solution is this. The front passenger side door only opens from the outside. Ppl have to always roll down the window to open it. When i open the door, I see the thee screws that surrounds the locking mechanism. But one is missing and the last two are so loose that when you close the door they slip out a little. Can I fix it myself or do i have to get the mechanic to fix it. I want to take my drivers test in it but i get docked points if the instructor cant open the door from the inside. Please help!
Old Mar 16, 2011
SpeedDownZone's Avatar
Re: front Passenger side door will not open
did you take the door panel off to see if the hook is connected to the inside door handle
Old Mar 16, 2011
rayaman2's Avatar
no im afraid to take the panel off. I was hoping maybe it was the screws. One is missing and the other 2 are loose.
Old Mar 16, 2011
your taking about the screws that hold the lock in place right. I dont think it that unless you see it moving alot when you pull the the handle, and by alot i mean about a inch. I still think that the hook is off, it happens like when someone installs a aftermarket speaker and just forget to install the hook back. Just look there i wont be hard to take off.
Old Mar 16, 2011
CraigW's Avatar
Take the inside handle out and make sure it's linkage is connected to inside handle. Take the linkage loose and pull on the L end to see if door will open.
Tighten screws you have in latch.
Old Mar 17, 2011
kc8ktq's Avatar
kc8ktq can only hope to improve
Child Safety Lock may have gotten flipped. Open the door, and check on the latch itself. Usually there is a metal tab that needs to be flipped into the unlocked position.
Old Mar 17, 2011
I though that was only for the rear doors.
Old Mar 17, 2011
pridezzedirp's Avatar
sleeperdx
pridezzedirp is an unknown quantity at this point
The only way ypur gna fix it is by poping the door panel off its very easy and make sure tht the lil placfic peace is connected to the rod for the handle I had the same problem on my 96 dx and had it fixed same day hope this helps
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
timpan
May 18, 2015 07:06 AM
werdnahall
May 17, 2015 11:37 AM
ImmortalEX
Oct 31, 2001 10:00 PM
