Sponsored by:
Sponsored by: CARiD
Civic SI and RSX parts swap?
Old Apr 11, 2002
01EXtc's Avatar
01EXtc is an unknown quantity at this point
since both the Civic SI and the RSX have the same engines would the RSX parts work on an SI?? example, headers, intake? just curious. didnt bother to search if there was a thread on here, if there was, sorry
Old Apr 11, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
what are you talking about? the civic si does NOT have the same engine as the RSX's
Old Apr 11, 2002
Machina's Avatar
Machina is an unknown quantity at this point
Old Apr 11, 2002
Zolutar's Avatar
From: Utah, while roaming Montana, Idaho and Wyoming
Zolutar is an unknown quantity at this point
aroo?
2k2 Si(R) HB, k203 160 hp
2k2 RSX (base) k203 160 hp
2k2 RSX (premium) k203 160 hp
2k2 RSX type s K202 200 hp
2k2 rsx JDM type R K201? 220 hp
cdn designation in brackets
the engine bay is virtually identical in layout in all
they are the same engine though the type S and JDM type R have a higher hp rating so there would be some differences in parts with those 2
I would think intake and headers would work fine, for the 160 hp version, the muffler however, no as the piping would be different
the older 99-00 b16a coupes had an aftermarket already prepared as it was the same engine used in the 94-97 b16a Delsol Vtec's though completely different chassis, only the engine parts were available already, ie headers, cams, etc, though the intake had to be redesigned for the si coupe, but the delsol version would have worked with mounting modification.
Old Apr 11, 2002
Club2005's Avatar
Club2005 is an unknown quantity at this point
OWNED!
Old Apr 11, 2002
Wanger's Avatar
RSX= 141 lb.-ft. @ 4000 rpm
CIVIC SI = 132 lb-ft. @ 5,000 rpm
i said the engines are different, different torque numbers means they are different "somehow", i wasn't saying they aren't based off something similar. as for swapping parts, something little like, the difference in these engines might have different parts jabbing somewhere, where one jabs and the the other doesn't, so be very careful when swapping. just want to give a heads up cause swapping stuff is no joke
REOWNED.
RSX
CIVIC SI
Old Apr 11, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
if the engine codes are the same, i am very sorry to tell you, but the engines ARE the same.......it could be as simple as a ECU swap to get the torque numbers up to the same as the RSX (base)......
OWNED.(LOL)
Old Apr 11, 2002
Bridge's Avatar
Bridge is an unknown quantity at this point
<< [i]RSX= 141 lb.-ft. @ 4000 rpm
REOWNED.
<< [i]
Acctually not reowned at all.... They are exactly the same engine. What gives the different torque #'s is a different final drive ratio.
Old Apr 11, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
K20A (RSX) = K20A (Si)
the difference in numbers is either in the ECU or the transmission or both. the only issue i would see with swapping parts would be the engine bay layouts. so while the part may actually fit on the engine, it may not necessarily fit in the engine bay. from what i hear, the Si engine bay has everything really crammed in there. parts may not physically fit in there, so be careful.
Old Apr 11, 2002
Grey's Avatar
DIY King
Anyway... A header would mate up to the engine properly, but who knows if it would mate up to the catalytic converter or down pipe? Same thing with an intake, it outside of the enigne. You asking if the engines are similiar and you're asking about stuff outside of the engine. I bet pistons, valves, rocker arms, cam shafts, heads, crank shafts, and all the engine internals will be swapable, but the other stuff is still a mystery IMO.
Old Apr 11, 2002
01EXtc's Avatar
i do see what alot of you are saying with the engine bay layout, i know it will be awhile until SI parts trickle out so i thought i could jump the gun
Old May 17, 2002
2k1HXVTEC's Avatar
THE CHOSEN ONE
2k1HXVTEC should not be trusted2k1HXVTEC should not be trusted2k1HXVTEC should not be trusted
btw, the difference between the rsx-s and the base rsx/civic si is that the type s and type r engines use a three rocker arm system while the base rsx/'vic si use a dual rocker vtec. plus they both have the variable intake cam. it has very little to do with final drive ratio or compression
Old May 18, 2002
TylerH26's Avatar
TylerH26 is an unknown quantity at this point
The RSX's engine is on the other side of the engine bay
Old May 18, 2002
blkEM1's Avatar
blkEM1 is an unknown quantity at this point
guys, the base RSX and new Si ARE the same engine. K20A3- the reason for the torque difference is that the Si uses the Type-S intake manifold.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
slikor
Nov 1, 2001 04:13 PM
