Sponsored by:
Sponsored by: CARiD
How can I tell if my 98 civic ex has an AT engine or MT engine?
Old Feb 4, 2009
  #31
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
Re: How can I tell if my 98 civic ex has an AT engine or MT engine?
Thanks sql, that's good to know.
Old Feb 13, 2009
  #32
obagain's Avatar
obagain is an unknown quantity at this point
I am not a mechanic, but I just bought an engine from a reputible place and when it arrived the intake is different.
I have a manual trans and everything else matches, I am using my old intake and that is the only problem.
Is there a way to make these work?
Old Feb 14, 2009
  #33
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ the intake itself or the intake manifold? if you bought the engine to directly replace an old engine they gave you the wrong engine if the intake manifold is different. if just the intake is different you should be good.
Old Feb 14, 2009
  #34
01_EM2's Avatar
01_EM2 can only hope to improve
idk if this may help but to tell the y8 motors apart the auto motors came with the iac valva on the throttle body where as the iac valve came on the back of the intake manifold for the manual motors
Old Feb 26, 2009
  #35
omegared99's Avatar
omegared99 is an unknown quantity at this point
I could have swore there was a difference between a motor that came with a manual trans and one with auto and its the "cam Profile" the automatics have a more tame profile than the manual. Correct me if im wrong but there is some differenes.
Old Feb 26, 2009
  #36
sql_civic's Avatar
There is no difference between the AT and MT D16Y8 cams.
Old Mar 9, 2009
  #37
ramonjones16's Avatar
ramonjones16 is an unknown quantity at this point
Originally Posted by TOEnail
....look at your pedals.
2 pedals = brake & throttle AT
3 pedals = clutch, brake & throttle MT
or look at your shifter..
if you see P, R, N, D its AT
if you see 1, 2, 3, 4, 5, R its MT
Agreed!
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Unstoppable
Nov 7, 2001 11:50 PM
