Sponsored by:
Sponsored by: CARiD
reverse bulb?
Old Mar 16, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
reverse bulb?
on the reverse bulb, there is a black clip on the bulb once you pull it out of the wire harness. Does this clip come off? I want to replace that bulb with some 7440's that i bought, but they don't have a clip on them.
Old Mar 16, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
no!! it is just a mono filament bulb!! so it doesnt matter which way it goes in! So there for you dontneed the clip!Dakota
Old Mar 16, 2002
thanks pimp
Old Mar 16, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Do you have a coupe or sedan. I bought a set of PIAA extreme white 7440's for the reverse bulbs and they DON'T fit in the coupes !! It takes a different type bulb. Does anyone know what fits the coupes ??
Old Mar 16, 2002
yeah man, i just figured that out, the 7440's dont fit, reverse or turn signals. reverse says style 921, turn signal bulb is 3156
i got a coupe too.
Old Mar 16, 2002
BAK's Avatar
BAK
I wonder what the equivelent of the 921 is ?? I can't find crap for that number ! I wonder if a W2 bulb will work? It looks pretty close to it and is 18W.
Old Mar 16, 2002
Voiceofid's Avatar
End Bringer
the reverse is the same bulb as ur parking bulb
Old Mar 16, 2002
yeah 168, 194, and 921 are all the same bulbs as far as fitting. Not sure about bulb size and wattage, but all of those bulbs are interchangeable.
921 bulb linkage
Old Mar 16, 2002
BAK's Avatar
BAK
168 & 194 are only 5W, which is way too dim. But you linked the ones I want (912/921) !
Thanks !!
Old Mar 16, 2002
BAK's Avatar
BAK
I just checked the 912/921 part number (19224) on that site against PIAA's site and it looks like W2 (19224) is the same exact part number. Options Auto Salon has them for $9.95 a pair.
Old Mar 16, 2002
Doh! i ordered them already. i guess i didn't search enough!
cferry7
Oct 18, 2015 06:32 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
MamaBear2015
Sep 4, 2015 09:04 PM
