Sponsored by:
Sponsored by: CARiD
Blow-Off Valves??
Old Mar 12, 2002
fourkilos's Avatar
fourkilos is an unknown quantity at this point
Blow-Off Valves??
can some one tell me wat a Blow-Off Valves does? and is it only used for turbos??
Old Mar 12, 2002
Mbow's Avatar
Yes, it is only used for turbos I am almost positive. I think that it releases the pressure from the turbo when you shift so it doesn't rev the heck out of it when it's not in gear.
Old Mar 12, 2002
sentinel's Avatar
sentinel is an unknown quantity at this point
yes it is only used on a blow off valce and no it isn't so it doesn't rev, its to help preserve the turbo. it releases the preasure created by the turboine. you don't want the preasure to push back into the turbo otherwise it'll slow the turbine down. you souldn't be concerned with blow off valves unless you have a turbo. and i think there are only a couple 7th gen civics with turbos.
Old Mar 12, 2002
blouisgod's Avatar
Life Begins > 6800rpms
the vortech sc has em too.
Old Mar 12, 2002
tRu's Avatar
tRu
tRu is an unknown quantity at this point
the blow off valve release pressures put on the piping and the actual turbine and without it it might have enough presure to backspin the turbine cracking your turbo or it might just denate your motor and with a better blow off valve the quiker the air is release the faster the spool up and superchargers can use it but in order to use it you musy have some pressure in piping superchargr doesnt require it some does anything thats has enough psi will need it but it wont work on any Naturaly aspirated
Knowledge is contagious (truth)
h4ldol
Apr 24, 2017 08:16 PM
rallyeredem0
Nov 2, 2015 10:56 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
BJB
Sep 14, 2015 11:16 PM
