Just lowered civic 2" with Tech 5 springs...look!
Rep Power: 0 If you look, the front fender is cut higher than the rear one. It looks like its lower in the back but it sits even. I saw that too but the rear tires are tucking like they should.
Rep Power: 0 the back looks aiite but the front is still kinda high...when u have couple people in the back your exhaust will scratch...and not to mention look weird as hell because the back is gonna be so much lower than the front when your driving...
Rep Power: 0 I rarely have peopl in the back but we'll test your threory this coming Monday when I pick up my girlfriend and her roomate and all their luggage at the airport.
Rep Power: 0 HEY WUT KIND OF SPRINGS DID U PUT IN THERE??? IS THE BACK LOWER THAN THE FRONT??CUZ ON MINE, ITS ALSO A 2 IN DROP FRONT AND BACK BUT THE REAR TUCKS LIKE CRAZY..JUSS WONDERING WUT KIND OF SPRINGS U GOT ON UR KAR.. BUT IT LOOKS KEW THO..[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Rep Power: 0 i had tech 5 coil overs but they wouldnt fit...so i bought progress springs...is the ride good with the Tech 5 springs? Are they lowering springs or coil overs?
Rep Power: 0 I have Tech 5 springs and they're as cheap as the progress springs with the same drop. I have some rear wheel tuck but its not bad. The ride is ok...a little more bumpy. Im sure that until I put new shocks in its gonna be a little more bumpy than it was.
Rep Power: 0 better get some new struts!!! Cause your gonna blowem! i guarantee that in 2 months youll be posting!"" blew my struts in the rear WTF?" I have told many people that those springs are $hitty and that they have a bad tendency to settle weird ! But you will blow your struts!! And if you dont have people in the rear of your car why did you buy a sedan??? JUST wondering? Dakota
Rep Power: 0 dontlisten to them u dont need new struts...your not going to blow them unless u keep on faking around on big a$$ dips..but i wouldnt get struts..i didnt get knew ones, and im fine...
Rep Power: 0 looks bad. why would anyone like that squatty look? The only lowering springs worth buying are Neuspeed and H&R because the engineers are actually intelligent about the design. The springs lower the front more than the back to achieve equal or very close to equal gap between tire and fender well. Coil-overs would be the best because the car can be perfectly adjusted.
Take back these Tech 5 springs and get something that will make your sedan look like it was properly lowered.
usajags84
15
08-19-2015 03:12 AM
