wiring diagram for 02 SI hatch
Originally Posted by se7engen_riDe
tried to search for it but no luck. is there a wiring diagram somewhere so my friend can install his viper alarm system?
12volts white + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/red + ignition harness
Second Accessory white/red + ignition harness
Keysense red/white - ignition harness
Power Lock white/blue - gray plug above drivers kick
Power Unlock white/green - gray plug above drivers kick
Lock Motor yellow/black back of the fusebox
Notes: In the top left plug.
Unlock Motor yellow/green back of the fusebox
Parking Lights+ red/black back of the fusebox
Parking Lights- blue factory alarm plug
Notes: The factory alarm plug is a green plug above the drivers kick panel.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light green + driver kick panel
Door Trigger - factory alarm plug
The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white.
Dome Supervision comes on with unlock
Trunk/Hatch Pin red - factory alarm plug
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue test connector
Notes: It is a 2 pin plug to the passenger side of the battery.
Wait to start N/A
Brake Wire white/black + brake pedal switch
Parking Brake
Horn Trigger orange - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
gmiguel
Jul 30, 2015 10:52 AM
sch2cm
Jul 21, 2015 09:58 PM
NoobyKid
Jul 18, 2015 02:01 PM
robbie374
Jul 7, 2015 02:56 AM
