Sponsored by:
Sponsored by: CARiD
Question on lowering car
Old Mar 3, 2002
SuperCivic2k1's Avatar
SuperCivic2k1 is an unknown quantity at this point
hey fellow 2k1 and 2k2 member, i am getting 17 rims and a full coilover kits, ppl told me to get other stuff that if i lower more then 2.0 like a chamber kit and konis and some other Sh*t..what do you guys think i should get if i lower my car 2.0?? please dont reply back if your gonna flame on me cuz i already did a search and didnt find any useful information..thanks
Old Mar 3, 2002
KurupTLX's Avatar
KurupTLX is an unknown quantity at this point
Koni Adjustables, definitly a rear camber kit, maybe a front camber kit but it may not be necessary if its just over 2". You're also gonna need an alignment...
K-lx
Old Mar 3, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
are you getting FULL coilovers? or ADJUSTABLE springs....so many ppl confuse the two.... GROUND CONTROL are not COILOVERS...they are ADJUSTABLE springs!!!!!!! GRRRRRRRRRRR
Old Mar 3, 2002
bake's Avatar
bake is an unknown quantity at this point
koni yellows, full camber kit and then your springs
Old Mar 3, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
koni's and camber.. ppl do get mix up with those.
those are coilover sleeve springs..
Old Mar 3, 2002
Essa's Avatar
Essa is an unknown quantity at this point
I assume you are going to install an adjustable spring like ground control. If you lower your car max 2", you don't need front camber kit because you could just do shimming or get it allign. For your rear suspension, you should get a rear camber kit if you don't want any negative number.
Your rear stock shocks can handle max 2" drop. Nice to have koni install for better handling and cornering. If you go more than 2", you start bottoming your shocks....no matter what kind of shocks since you only have about 1" of travel. Unless you could find a shorter shocks with body length 7" or less.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
PS: Tell me if you can find a shorter shocks, since I'm also looking for it[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Mar 3, 2002
Mbow's Avatar
IMO you will need camber kits for all four corners, and most definately some performance shocks.
Old Mar 4, 2002
hey, thanks for answering my question, now, where can i find this "konis" and "chamber kits"?? that is cheap..
now for my next question...i want to get 17' rims and ppl say that if i get bigger then 15' my tranny and gear ratio will be gone really fast, now how do i get 17' and prevent it from loosing my tranny and gear ratio so i could have a clean ride?? thanks
Old Mar 4, 2002
Essa's Avatar
Well, something must be sacrifice. Yes, your tranny and gear ratio will be gone faster than using stock wheels, but it won't be gone as fast as you think. It's also depend on how you drive your car.
Where to buy the Koni and camber kit? Try using the Parts table?
Old Mar 4, 2002
Bartkat's Avatar
I ordered my Koni Sports here for $515, the best every day price I've seen. They shipped same day and the shocks and struts are due to be delivered tomorrow.
KONI SPORT SHOCKS AT IMPORT HORIZON
Old Mar 4, 2002
Bartkat's Avatar
<< Well, something must be sacrifice. Yes, your tranny and gear ratio will be gone faster than using stock wheels, but it won't be gone as fast as you think. It's also depend on how you drive your car.
I'm not sure I understand how going to larger wheel diameter will change the overall ratio or damage the trans, if the same overall tire diameter as stock is maintained.
Old Mar 4, 2002
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
<< I'm not sure I understand how going to larger wheel diameter will change the overall ratio or damage the trans, if the same overall tire diameter as stock is maintained. >>
yah...thats what i've been thinking...if you get 17" rims with low profile tires..then i should be around the same TOTAL diameter as stock 15" with those phat rubbers
Old Mar 5, 2002
Umm...i dont get it..if i ket 17' rims should i get a new tire if so what kind is the one and what size will it be in?? and D.A.M.N Konis is sooo expensive...they are like 500 bucks, welll i will try to get everything to get my ride a smooth and safe one. i wanted the tenzo R Rims. and i want it to be 17 and not mess up my tranny and gear ratio..plz reply back for more detail to make my ride smooth and will last long * and i dont want to hear, "keep it stock"* ok well reply back!
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
bsmiley
Apr 27, 2015 01:27 PM
2Hondaz
Nov 8, 2001 11:00 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
Zillaaa
Nov 2, 2001 05:11 PM
