reverse indiglo
yes there good i bought the el reverse indiglo gauges they fit right over the oem ones.......they lite up blue and red really cool wit dimmer switch......i got mine from this guy on ebay his user name is 17play
ok cool lata
ok cool lata
I got the A7 EL wire gauges from Autotechnic - i love em, installation is a little tedious and required some 'personal' touch, but all in all, great deal! Also got on ebay... heres pics in my profile!
http://hondashowoff.com/profile.php?id=5688
they are cool, but i had a lot of problem with mine..i couldn't get them to lay flat enough and my speedo needles would get stuck. I ripped them out a couple of months back..good luck. They are nice, i enjoyed them while i had them
Yeah i had similar problem at first with the speedometer, but no the RPM gauge... used some double sided scotch tape and worked out fine =D as i said tedious, GL!
BTW> i also had to cut into the botom EL part to be able to get around needles... You can see the cut out (although a clean cut) righ tthrough the 'titanum' STICKER in the middle.... I dont mind, looks fine, cut clean though, you WILL see it when the light is on!
nirvanaguy
25
Oct 26, 2017 07:26 PM
velozp
Dec 13, 2015 11:28 AM
ThatGuy913
Sep 28, 2015 05:35 PM
BBrosario
Sep 17, 2015 07:51 PM
