Question About Hood Pins for CF Hoods?!
Super JDM Member
Im gettin a CF hood shortly and am going to purchase hood pins. Is there a huge difference between the latch ones, and the ones that u need a key for in terms of strength (keeping the hood down)? What should i look for when buying hood pins or is it all the same? anything i should stay away from?thanks for the help
i have the ones with the key and the VIS hood i have is too thick to install them properly into. I had to get pins for it due to the skeleton being to think; it just depends on the hood. if you can use the key type, ill sell em to you super cheap since i have no use for them, they are the NRG carbon lockers.
Super JDM Member
hmm.. those are the ones im interested in actually... but i am getting a VIS hood also.. so im assuming they wont be good for it either... unless different VIS hoods are different thicknesses.
Originally Posted by HonCivX02
^depends on style.... some spots are thicker then the same spots on a differently designed hood.
yeah it depends on the style. the skeleton on the invader extreme hood that i have is pretty thick. there isnt a real spot to mount hood pins at all. just see what the underside of the hood looks like when you get it i guess.
Dave1984
Jul 22, 2015 06:10 PM
Touge
Ottawa
Jul 18, 2015 05:39 PM
Touge
Jul 18, 2015 05:35 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
