Sponsored by:
Sponsored by: CARiD
Damn Projectors
Old Feb 21, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
Damn Projectors
This is the second set of H3 super plasma PIAA bulbs in 3 months. The Passenger side bulb burnt out. This is the second time. There is a brown stain on the bulb like moisture or something like that but no leaks?! The bulbs are warranted but this is getting to be a pain in the @ss. NO, I didn't touch the glass either time, I'm sure. WTF[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Feb 21, 2002
thundercats4ever's Avatar
thundercats4ever is an unknown quantity at this point
That sucks! I sure hope mine don't do that when I get them.
Old Feb 21, 2002
Bartkat's Avatar
PIAA bulbs are like playing the lottery.
Old Feb 21, 2002
bottlefed's Avatar
bottlefed is an unknown quantity at this point
my projectors blew 3 sets. it only blows the high wattage bulbs like 100 watts. the only ones they don't blow are the low wattage plain *** old white bulbs. it sucks cause it doesn't look as good. i hate this
Old Feb 21, 2002
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
The confined space in the projector versus the open space of the normal light assembly is the problem. You'll never get a set to work for very long if they're higher wattage. My advice: HIDs. Works beautifully, and for over 6 months now on the same bulbs.
Old Feb 22, 2002
bottlefed's Avatar
what do u mean by HID's. Are you talking about the HID system. How much was it? Or are you talking about just HID look bulbs
Old Feb 22, 2002
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
i think hes talkin abut the HID system..which around here you can get for about $650. But good luck gettin the bulb to fit right, and not melt the housing. There is a special way that you can set it up, but its kind of tricky from what i hear to get it to work on our projector setup. This is because the HID bulb is much longer than the regular H3.
Old Feb 22, 2002
ImportAzn21's Avatar
ImportAzn21 is an unknown quantity at this point
hey are you guys speaking of the dot approved projecter? or the regular style projecters that first came out?
scott
Old Feb 22, 2002
And i'm sure that the dot uses h4......h3? how do you convert?
scott
Old Feb 22, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
did u think that maybe its not the projectors, but yet the BULBS INSTEAD! the projector beam has NOTHING to do with blowing bulbs....
Old Feb 22, 2002
01blackCVC's Avatar
01blackCVC is an unknown quantity at this point
My projector bulb blew out as well, it had the black stains on it after I took it out. I found out that my passenger side projectors had moisture in it and I have recently re-sealed it after I dried it out and it hasnt given me any trouble since then. I also put hyper white H1 for hi-beam and H3 for lows.
Old Feb 22, 2002
tcneo's Avatar
tcneo is an unknown quantity at this point
mwwhonda: which bulb did u use for your projector(low beam) ? and how much and where did u get the TYC for ? that headlight kick some *** hehehe....
Old Feb 23, 2002
bottlefed's Avatar
<< did u think that maybe its not the projectors, but yet the BULBS INSTEAD! the projector beam has NOTHING to do with blowing bulbs.... >>
Are you kidding? How could 4 different sets of 4 different bulbs of super whites blow out in my projectors and not in my factory headlights? There is a plug that converts the h4 into a H3 so maybe something is wrong with the wireing or it just most likely gets too hot in the projector housing and just blows
Old Feb 23, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I'm using PIAA xtreme white H3's in my projectrs with no problems, (this better not jinx me by posting this) Anyways Mine only use 55w but put out 110w of light, I am happy with them. I gotta get the xtreme white h1's for my high beam and then i'll be all set.
Old Feb 23, 2002
bottlefed's Avatar
How long have you had the PIAA's? cause i heard from alot of people that there piaa's kept blowing and you know how much they are to just keep buying like this
Old Feb 24, 2002
I don't understand........we have to use different bulbs for projector headlights?
How do you convert a h4 harness to work with h3?
Which projectors are you talking about?
They tyc is the dot approved ones right? Just to clear things up a little
scott
Old Feb 24, 2002
pmau's Avatar
pmau is an unknown quantity at this point
To fix the problem people are having with their bulbs blowing, you HAVE to use only 55 watt draw bulbs. The reason for this is because when you use xenon type bulbs they already have a shorter life than halogen bulbs, therefore the higher wattage you use for xenon type bulbs, the shorter the life and don't forget that projector lights tend to draw more wattage from any bulbs you put in.
Old Feb 24, 2002
bottlefed's Avatar
<< I don't understand........we have to use different bulbs for projector headlights? >>
Yeah, there is a wire with a plug at the end coming out of the back of the projector which plugs into the other plug that is suposed to connect the the end of a H4 bulb.
Old Feb 24, 2002
bottlefed's Avatar
<< To fix the problem people are having with their bulbs blowing, you HAVE to use only 55 watt draw bulbs >>
Yes i know this i already said that but it really sucks cause they don't look as good.
JetsterDajet
52
May 8, 2016 12:11 AM
wingsfan19
Oct 1, 2015 03:45 AM
baconomics
Aug 26, 2015 07:47 AM
JetsterDajet
Aug 15, 2015 08:07 AM
