Sponsored by:
Sponsored by: CARiD
NEED HELP WITH KONIS
Old Feb 17, 2002
TOOLOWCIVIC's Avatar
I can't seem to adjust the back shocks. I already moved the little piece of metal so I can use the *** but it won't turn. Anybody have any advice to what I can do to adjust it.
Old Feb 17, 2002
rhyno's Avatar
rhyno is an unknown quantity at this point
moved what piece of metal? pull up the carpets, throw the little **** onto the top of the strut, and turn. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
you can try some pliers. just be gentle
Old Feb 17, 2002
vtecdoc's Avatar
vtecdoc is an unknown quantity at this point
Well they are set all the way soft from the factory, and it wont go anyfarther that way but it should turn the other way, my problem is I cant tell when to stop turning. Any way sounds like you better give Koni a call.
Old Apr 4, 2002
Bartkat's Avatar
<< moved what piece of metal? pull up the carpets, throw the little **** onto the top of the strut, and turn. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
There is a piece of seat frame that is in the way of the ****, at least on the EX coupe. I need to know how to remove or bend that piece of metal.
As for adjustment it looks like there is a total of two full turns available. According to Koni, one adjustment is 180 degrees or half a turn. The softest setting is full clockwise, and you go counter clockwise to make them stiffer. You can tell how far you turned by watching where the little arrow on the **** starts out and where you stop. Two full turns should hit the stops.
Old Apr 4, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
try turning the other way, clockwise
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
cukaracha
Aug 29, 2015 05:27 PM
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
