Sponsored by:
Sponsored by: CARiD
?? camber Gage ??
Old Jan 19, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
?? camber Gage ??
Has any one here ever used one of these http://cgi.ebay.com/ebaymotors/ws/eB...48?refid=store If so what do you think of it? do you think its accurate?
Old Jan 19, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
definitely don't use one like that. The car needs to be loaded on the ground for it to read accurately AND the ground must be perfectly level, and the magnet won't stick to aluminum wheels obviously. Look up the Pole Position FastTrax gauge. Ones like that work better than the magnet ones because they grab the wheel lip and can be corrected for uneven ground.
Old Jan 20, 2006
tfnaaf's Avatar
BLDNPSI Mod
Well it could be used with the car on the ground but it would require some sort of adater to be able to attach it to the hub. I've seen these adapter YEARS ago but i seriously doubt they are manufactured anymore. My guess is you would need to fab up one some how. In todays shop that is used as a guage to check the camber before you make a suspension change . Then use it to return the suspension to the same camber AFTER the change and works VERY well for this. But prolly not the best solution for setting your alignment.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
