Sponsored by:
Sponsored by: CARiD
Installed Konis yesterday
Old Feb 10, 2002
doublins's Avatar
doublins is an unknown quantity at this point
All i can say is that even at the softest setting, they kill the stock shocks (mind you my stock shocks were all blown just from my Eibach pro-kit (1"drop, but much higher spring rate). Anyway, they ride very nice. Question for suspension gurus tho... how stiff should I set them? I have stiffened up the rear 180 degrees to stop bounciness, and the fronts a little more, but I don't want to go too stiff so I mess up my suspension or bend something on a pothole. What's the best setting for our car to cut back on dive and roll, yet give a comfortable ride? Particularly people with konis should respond. Thanks.
-C
Old Feb 10, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
keep the back a little tighter than the front, sounds like you have it set pretty good, dont worry about bending anything, crank them 360 and cruise with them stiff sometimes, it feels cool, like a racecar
Old Feb 10, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
This has nothing to do with what you asked.....
If i get the pro-kit, I'll most likely blow all my struts????
Old Feb 10, 2002
ModNewbieHELPME's Avatar
ModNewbieHELPME is an unknown quantity at this point
whether you blow your shocks depends on many things...the agressivness in the way you drive being one....any weak points in the shock being another...I know a couple people who have yet to blow theirs and have a 2" drop. All a matter of luck.
But eventually you'll need to upgrade.
Old Feb 11, 2002
showoff's Avatar
showoff is an unknown quantity at this point
I kept my konis set on whatever came outta the box. I imediately felt a drop in roll,dive croutching and bounciness as is. Im gonna play with the settings when warmer temperatures comes around.
Old Feb 11, 2002
sonsonzai's Avatar
sonsonzai is an unknown quantity at this point
they really ride very nice, I'm no longer afraid of going on any bumper or curves...
but the bad thing is the guy who installed it told me that I can't adjust the rear without taking it out. he said there's a piece of metal blocking the way in twisting the cap. can anyone tell me if it's true?
Old Feb 11, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
So do you guys with springs and koni's hear a lot of creaking noises while driving ????
Old Feb 11, 2002
Bartkat's Avatar
How long did you run the stock shocks and struts with the pro kit before the shocks blew? I have the pro kit ordered but want to wait for the Tokico shocks.
Old Feb 11, 2002
VTECnique's Avatar
VTECnique is an unknown quantity at this point
I have GCs, my struts are blown, and i'm waiting on my Koni's...will i damage anything if i'm hitting bumps and potholes too much/hard? I'm starting to feel more roll in my right turns than in my left????? [IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 12, 2002
NightHawk's Avatar
NightHawk is an unknown quantity at this point
i had eibach coil overs---front shocks were gone. Definetly an investment in Koni's...or any new shocks for that matter!
Old Feb 12, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
I've had my Konis for a few weeks now, and I've had plenty of time to "play" with the damping to get it to feel how I want it too. Right now I have both the front and rears a little more then 180, my front is a little stiffer than the rear, cause I've got a couple hundred pounds of audio stuff in the trunk. With my GC's set as low as they are, I've got about 1.5" of travel on the front Koni's before the bumpstops. And what's nice about that, is cause I don't bottom out.
Old Feb 13, 2002
doublins's Avatar
About the blockage in the back-- I have been able to adjust them with pliers... Yes, it sucks that the "key" does not fit in because of that piece of metal, but needle nose pliers work fine.
Old Feb 17, 2002
vtecdoc's Avatar
vtecdoc is an unknown quantity at this point
I just took some pliers and bent the metal out of the way. Then the ***** fit fine.
Old Feb 21, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
my dad made me some cool real thin billet ***** for the rears...cool deal!
Old Feb 21, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
how much did you guys get them for? cause i will have to get them soon for neuspeed race?
and is the handling alot difference?/?
Old Feb 21, 2002
Matrix's Avatar
Matrix is an unknown quantity at this point
"and is the handling alot difference?/?"
I want to know too.
Causemo
Jul 4, 2015 07:11 AM
cukaracha
Jun 7, 2015 03:32 PM
HiImBrandon
Jun 1, 2015 07:34 AM
