Sponsored by:
Sponsored by: CARiD
Help with vafc2
Old Oct 6, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Help with vafc2
It keeps reseting on me... WHat am I doing wrong?
Do you have to do the gas for 10 seconds then off for ten seconds then shut car off thing everytime you change settings? Cause I havn't been.
Old Oct 6, 2005
Blahman240's Avatar
It may posibly be cause I was hitting initialize all.
Old Oct 6, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
the initialize is to reset it.....
Old Oct 6, 2005
Blahman240's Avatar
Thanks, I just found that out by reading online... But mods don't lock the topic yet... Lets see how it works after some driving. I'll update later tonight.
Old Oct 6, 2005
Blahman240's Avatar
but wait... do you have to do the 10 on throttle 10 off thing whenever you change settings?
Old Oct 6, 2005
Turbociv's Avatar
Turbociv has a little shameless behaviour in the past
Yes u have to do the throttle. And when you are wiring i had the same problem with it reseting. The two positives have to be spliced into the wire. You cannot splics into the wire you spliced fromt he Vafc2
Old Oct 6, 2005
absolut_vodka98's Avatar
absolut_vodka98 will become famous soon enoughabsolut_vodka98 will become famous soon enough
It'll be interesting to see if it even works. Doens't work in my 5speed EX. When I hook up the vtec wires, my car goes ti hell in a hand basket. Or at least 1st gear taking off is great, then my RPM's wont let me go over 3 or 4k. (can't remeber which one.)
Old Oct 6, 2005
Turbociv's Avatar
Ya mine did the same. Some of the models kick into a engine safe mode which wont let them go over 4 grand. Do not set the vtec and it will engage around 3100. I have not yet figure out how to bypass this. It just depens on which models you have
Old Oct 6, 2005
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
Where is ur engangement at for VTEC because if its too low it will egnage and it start to lug. My suggestion do not try to set this urself get it dynoed and let somebodt who knows what there doing handle this. BC if u dont u will screw upo the car and that $400 dollar piece of equipment.
Old Oct 6, 2005
Valdeezy's Avatar
When I first got mine I tried to do it myself. I could not get over 3k without it lugging and cutting out. There are alot of different settings that come alopng with the VFAC II. GET IT DYNOED. It will not work right until all settings are set correctley. Now that it is set up correcley my engagment point is 2400. hahah BEAT THAT.
Old Oct 6, 2005
Blahman240's Avatar
the thing you are describing happened to me, did you use wire taps? They don't make a good connection. I went back and soldered and now everything works amazing. BTW I figured the problem out.
Old Oct 6, 2005
Blahman240's Avatar
You're going to bend a valve or wear out a bearing or something... There isn't enough oil pressure for it to be that low.
Old Oct 12, 2005
Valdeezy's Avatar
Y do u say that ur the second person to ask about the oil pressure. If thats the case its gona go up but let me know thanks.
Old Oct 12, 2005
Blahman240's Avatar
No, its too low of pressure for vtec... It won't shoot up the pressure.
Rennen
Nov 21, 2006 12:16 AM
aznstylez254
Jun 23, 2006 12:56 AM
jayrck81
Mar 5, 2006 12:31 PM
MiamiUgen7
Sep 12, 2005 05:10 PM
xproductionz
Aug 30, 2004 01:30 PM
