MSD Rev Limeter
G'z UP
MSD Rev Limeter
Does the MSD rev limerter work with our cars its says that it will work on virtually any ignition system
Originally Posted by Killacamshaft
Its to get a good start you set it at eny rpm u want and when u realse the clutch it the rev limeter stops its also called a 2 step
There's no reason to try and raise the rev limiter on these motors. They shouldn't be revved that high, unless built. They won't handle the revs. Even if you could rev above 6500 rpm, you won't see any advantage in it.
You sir, are a moron. You're probably better off driving your fagomatics.
i insult becuase they guy was saying someone was stupid, and he was infact the wrong 1. If u dont know wat ur talknig about it, dont talk at all, or u could screw someone up.
Killercam was right on wat they do, then taz went and filled his head with incorrect thoughts, saying he was wrong.
Turbos, Engines, Chassis and Suspension Tech
What you are describing is a 2 step Vantage. You are semi correct, in the fact that it IS a rev limiter of sorts, however when people refer to a "rev limiter," they usually refer to a "redline" kind of thing.
SolidHollow
15
Sep 13, 2015 11:18 AM
Bikergofast
Sep 12, 2015 10:54 AM
Bricoleur
Sep 9, 2015 12:30 PM
