Sponsored by:
Sponsored by: CARiD
coolant question
Old Jan 3, 2002
joe's Avatar
joe
joe is an unknown quantity at this point
coolant question
i was wondering if it is okay to use prestone or do i have to use only honda coolant. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 3, 2002
eXNBP's Avatar
eXNBP is an unknown quantity at this point
Honda is the safe way to go, but if you really wanna save those few bucks then be my guest[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 3, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
Coolant is coolant....There really isn't much difference in coolants like there is oil and stuff.
Old Jan 3, 2002
Grey's Avatar
DIY King
Coolant for the radiator? There's this stuff called Water Wetter that makes your coolant work a little better. I reccoment that. Antifreeze with lower temperatures and higher thermal conductivity is good as well. I noticed my engine temp drop when I switched to my Tsunami front bumper. It exposed more of the radiator to the air. That's another thing to consider.
Old Jan 3, 2002
Bartkat's Avatar
Coolant is not all the same. This is especially true over some period of model years. I don't know why you would need coolant in a 2K1 Civic, but it is best to use what the manufacturer recommends, always.
Old Jan 3, 2002
02Si's Avatar
02Si is an unknown quantity at this point
Bartkat said, "I don't know why you would need coolant in a 2K1 Civic."
Why wouldn't our cars need coolant?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 3, 2002
CivicEX2k1's Avatar
CivicEX2k1 is an unknown quantity at this point
stick with what honda recomends for cooling. honda makes some good ish for cooling. also grab a bottle of "red line water wetter" (it is a additive for ur coolent). it supposbily lowers your temp up to 30degrees F. its some good stuff. take a look at it.
Old Jan 4, 2002
Doc's Avatar
Doc
Doc is an unknown quantity at this point
Do NOT use Prestone Coolant, it contains Silicate which is an abrasive material put into coolant to keep water passages free of rust and corosion in cast iron engine blocks. Your Honda engine is all aluminum, if you use Prestone it WILL reduce the life of your Water Pump. Use Honda coolant or Sierra Coolant they are both manufactured specificaly for aluminum engines.
Old Jan 4, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
<< Bartkat said, "I don't know why you would need coolant in a 2K1 Civic."
i think he means he doesnt know why you would need more already, its a new car
Old Jan 4, 2002
eXNBP's Avatar
<< Coolant is coolant....There really isn't much difference in coolants like there is oil and stuff. >>
Hmmm id have to disagree, Redline oil vs. Pennzoil ummmmmmm big diffy there buddy[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Jan 4, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
you don't have to get honda brand coolant. the manual says get honda brand everything. they put that in there in hopes to make more money off you.
Old Jan 4, 2002
AlphaInfinity's Avatar
AlphaInfinity is an unknown quantity at this point
I will be going with what honda sais until the warranty runs out. I don't want to give them any excuses.
cizsak
Jul 21, 2015 03:39 PM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
Bounddyy
Jul 8, 2015 11:22 AM
ZILLA
Jul 5, 2015 05:24 PM
