Sponsored by:
Sponsored by: CARiD
battery question?
Old Dec 21, 2004
runner1738's Avatar
battery question?
i just opened the hood and its been a while since ive been able to do work on my car, but it looks like there is batter acid on the of the battery, is that normal? my car has 31k miles on it and is about 2.5 years old? thanks
Old Dec 21, 2004
devilvtec's Avatar
devilvtec is an unknown quantity at this point
i dont have any on mine, sept 01 - 50,000 miles
Old Dec 21, 2004
takumi's Avatar
takumi is on a distinguished road
Is this the stock battery? What color is the acid?
Old Dec 21, 2004
runner1738's Avatar
yes its stock, white yellowish color
Old Dec 21, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
Sounds like its time for a new battery.....Batteries are not supposed to have acid on them.....in them, yes.....on them, no. Check to see if you still have a warrantee on it.
Old Dec 21, 2004
runner1738's Avatar
it should, but i guess i should just take it to honda for that right? since its there part
Old Dec 21, 2004
SIinthesky's Avatar
Go to the honda parts dept. not service. Its not hard to change yourself. Parts will be able to replace it. It might be cheaper to go with an aftermarket brand.
Old Dec 21, 2004
Civicious's Avatar
Civicious is an unknown quantity at this point
Mine finally died last weekend. Luckily I was at Sam's Club when it did. 3 1/2 years till I had to replace it though. Not bad at all.
Old Dec 21, 2004
streetglower's Avatar
are you sure it is acid, or is it corrosion? If it is corrosion, you can clean it with a mixture of baking soda and water. Look around the battery and see if you see any cracks or anything. Otherwise the battery just needs to be cleaned.
Old Dec 21, 2004
runner1738's Avatar
it looks like acid, but then what is corroision? maybe it does just need to be cleaned
Old Dec 21, 2004
It is hard to describe corrosion. It just happens over time. Things start to corrode. It usually happens around battery terminals and on the battery. Try cleaning it and see if it helps.
jferristx
Jul 8, 2015 10:09 PM
BootyDo
Jul 7, 2015 06:06 AM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
viper775
Dec 9, 2001 10:52 PM
