Sponsored by:
Sponsored by: CARiD
RSX Optional Shift Knob Install
Old Nov 19, 2004
DragonFly's Avatar
DragonFly is an unknown quantity at this point
RSX Optional Shift **** Install
Hey guys I just bought and installed an RSX optional shift ****. It's the all metal one. I followed the instructions to install it but it doesn't seem to go on right. When I tighten it untill it is secure, the gear numbers are all crooked. Like off to the side yknow? I tried to loosen it a little so that they would straighten but then it **** is all loose and it moves. Is there anything I can do to make it straight? Thanks.
Old Nov 19, 2004
gh0st's Avatar
TAQUITOS!!!!
loosening it just to straighten it out makes it wiggle around? sorry, i have no idea. are you putting it on the stock shifter? or do you have a revo ss?
just wondering cuz i want that ****, where'd you pick it up from?
Old Nov 19, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I have the Skunk2 shift **** and it came with a little nut that you use to lock the **** in the right position - it goes on before the actual **** itself. Did your shift **** come with one? If not, perhaps you can run out somewhere and get one - I don't have the thread specs on hand, but I'm sure if you search it's on here somewhere.
Old Dec 14, 2004
DragonFly's Avatar
im putting it on the stock shifter which i thought was identical to the RSX 5M shifter. yea it came with a little nut and i put the nut on before the **** but it still doesn't go on straight for some reason. the gear numbers are off center. did i tighten it too much or not enuf or what? i didnt use a wrench to tighten it or anything. should i? i was thinking of putting in a washer in there between the nut and the **** to see if that helps. what do you guys think?
i got it from this site http://www.acuraparts247.com/sunnyside/jsp/home.jsp
the part number is 08U92-S6M-200A
Old Dec 14, 2004
DragonFly's Avatar
Old Dec 14, 2004
TeLLy's Avatar
Put the nut all the way down the shifter, then turn the **** as far down as it will go with the numbers straight. There's still room on the shaft, so turn the nut back till it's snug with the shift ****. Then tighten the nut back with a wrench. Done.
Old Dec 14, 2004
xX03EXx's Avatar
Sweetest Dude on 7th Gen
^ Well said.
Old Dec 14, 2004
NeonImpact's Avatar
Forum Sponsor
That genius NeonImpact made a shift ****/boot fix thread one time.
You should check it out.
http://www.7thgencivic.com/forums/sh...d.php?t=132538
Old Dec 14, 2004
gh0st's Avatar
TAQUITOS!!!!
ooh **** that ***** nice...time to sell my base rsx for that one
Supramk3
Jun 11, 2015 11:13 AM
What_It_Do
May 10, 2015 05:31 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
NukeSilo
Nov 20, 2001 10:02 PM
StLVtec
Nov 14, 2001 09:22 PM
