Sponsored by:
Sponsored by: CARiD
NEED ANSWER QUICK-PLEASE!!!!!-repost
Old Oct 15, 2004
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
I know this is a repost, but am in the middle on an install, and don't got much time:
I was installing my rsx-s 19mm sway bar, and while removing the endlink bolts, i didn't realize you are supposed to use an allen wrench in the end of the bolt. anyways, i just turned the 14mm bolt until the whole bolt and everything was turning! afterwards i saw your supposed to hold the bolt with an allen wrench and then use the wrench to get it off. Anyways, i inspected the rubber boot, it looks okay, do you think the endlinks will be okay? I pried on them pretty hard, and like I said, the hole bolt was was just turning. Please help me....
Old Oct 15, 2004
djmota's Avatar
as long as they are not broken you are OK. If you don't have the allen key you can also use a small pair of vise grips and grab the ring in between the boot and the bar. Make sure you don't install it upside down.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Tyler93
Detailing
Oct 24, 2015 09:48 PM
Islesfan
Sep 29, 2015 03:42 AM
NROD315
Sep 23, 2015 03:46 PM
Jrosa
Sep 14, 2015 08:24 PM
