Sponsored by:
Sponsored by: CARiD
spark plug
Old Jul 10, 2004
cbaer543's Avatar
cbaer543 is an unknown quantity at this point
spark plug
I have heard that the iridium spark plugs can mess up your car is this true at all?
Old Jul 10, 2004
On a stock or lightly modded car, there is no problem. Iridium is actually better, because it requires less system voltage to generate the same spark. I've run regular plugs with my ported cylinder head and they started to foul in one day. I've been running iridium now with no problems for at least a year.
Now for turbo, everyone strongly recommends AGAINST using iridium. Regular copper is preferred.
Old Jul 10, 2004
cbaer543's Avatar
Also do they make spark plug wires for and 01 honda civic LX? I haven't seen any probley because of the coils it has.
Old Jul 10, 2004
zen_master's Avatar
u don't need to use the wires since 7thgencivic use a different system....it's that all-in-one coil tube..
anyway, iridium WONT mess up your car......except for turbo...maybe..
Old Jul 11, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
id say stick with copper no matter what the situation.
"it's that all-in-one coil tube.."
newer hondas use coil on plug ignition systems.
Old Jul 11, 2004
That's not always true. My car can't run properly on regular plugs, so I need the iridiums. I think they have a higher temp range.
Old Jul 11, 2004
ctx66's Avatar
then something is wrong with your car.
Old Jul 11, 2004
zen_master's Avatar
the OEM plugs are platinum...
and u r using copper?
Old Jul 11, 2004
Nothing is wrong. I'm just running higher compression, and Iridium won't get fouled as easily. The OEM plugs are supposed to be better than copper, since both electrodes are platinum coated. With iridium, the ground electrode is still nickel.
And I would use iridium simply because it uses ALOT less system voltage to make the same spark as copper plugs.
Old Jul 11, 2004
ctx66's Avatar
no, im using the stock plugs still since i have no reason to change them out. but when it does come time to replace them ill use copper.
higher compression, lower compression, no reason copper wouldnt work just as good. you probably had problems with the copper plugs since they were the wrong heat range
Old Jul 11, 2004
Yeah I think the copper ones I tried were a colder heat range, even though it's the stock part number. Someone said they're one step colder, and I think that's why they started to foul out.
Old Jul 11, 2004
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
what's a good upgrade from the OEM plugs? I was thinking SplitFires
Old Jul 11, 2004
ctx66's Avatar
ive heard nothing but bad things about splitfires. although this was in a different engine, not with civics.
Old Jul 11, 2004
Iridium is the only upgrade from stock. They need less voltage to run, and that's about the only difference.
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
