Sponsored by:
Sponsored by: CARiD
A/C question.
Old May 2, 2004
thomusvoo's Avatar
Newbie Member
thomusvoo is on a distinguished road
A/C question.
today in cali., its a fawken hot day. no kidding. its like 100 + degrees.
while driving down the road with the windows up and the A/C blasted.
i realized, my A/C is cold but not REALLY COLD.
thus leading to the question:
can i make my A/C any colder????
does anybody know how to make it colder?????
i want it so cold, it'll make my boogers freeze like in "Dumb and Dumber"
Old May 2, 2004
CvC-v01's Avatar
CvC-v01 has a little shameless behaviour in the past
charge your car with freon....
Old May 2, 2004
thomusvoo's Avatar
Newbie Member
where can i find that?
Old May 2, 2004
thomusvoo's Avatar
Newbie Member
^^^actually...
what is that??? =/
Old May 2, 2004
CvC-v01's Avatar
you have an 03...i don't think you really need to fill your car with freon
freon: nonflammable gaseous or liquid fluorinated hydrocarbons employed primarily as working fluids in refrigeration and air conditioning and as aerosol propellants.
in other words it what makes your car Ac air cold....
you only need to fill up your car with freon if your low
or if your Ac whoes are leaking air....
Old May 2, 2004
thomusvoo's Avatar
Newbie Member
wow. thanks.
so my car will be like a freezer!
thats amazing!
Old May 2, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
with R134a you cant. The generally accepted temperature change from ambient is 20 below actual outside temp. So if its 100F out, then it will be 80F. With an R12 system is a different story however, but since R12 is no longer in use, and you cant retrofit an r132a to R12, your SOL.
Old May 2, 2004
thomusvoo's Avatar
Newbie Member
noO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!^
Old May 2, 2004
Jo_Boo's Avatar
Jo_Boo is an unknown quantity at this point
The fluid doesnt evaporate either. If a shop says you need a recharge, ask them to check for a leak. It doesnt majically disappear, it has to go somewhere.
Tedverseti
Apr 23, 2020 01:45 PM
h4ldol
Apr 24, 2017 08:16 PM
jtcavey
Sep 30, 2015 02:18 PM
IronFist
Sep 25, 2015 07:13 PM
pilebuck13
Sep 21, 2015 10:45 PM
