Sponsored by:
Sponsored by: CARiD
Problem installing body kit.
Old Mar 13, 2004
DareDebil911's Avatar
DareDebil911 is an unknown quantity at this point
Well it is kit install time, and I am pre fitting all my parts before I send out for paint. My type b front lip will not fit all the way around the front without being forced to almost breaking. And the dimpled holes where you drill in my Xenon side skirts and rear, barely line up without being forced. Am I going to have to jack up my car to put the side skirts on? I have a 2002 LX sedan. Please help, this goes out for paint on Monday.
Old Mar 14, 2004
Anyone have any ideas?
Old Mar 14, 2004
If it doesn't fit, there's nothing you can do. Jacking up the car won't help. Maybe a body shop will be able to modify the parts so they fit on better.
Old Mar 14, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
i know for the type b front the fitment is really really tight. For me there was one side that had a sharp angle and the end (where it goes inside the wheel well), and the other side was a little less. What i did was put on the side with the sharp angle, and then had a friend help and stretch it to MAKE it fit. Its hard, but once its on it will stay without any screws and will not sag at all. Good luck
Old Mar 14, 2004
TeLLy's Avatar
Yes, it's an Acura EL
One thiing I leared with my body kit stuff is that it's best to leave the car with them so they can fit AND paint. Also allows them to paint match, especially if your car is a year or so old - paint fades and if you just go by the paint code on the door, the new painted parts won't match up to the old.
My front lip, when painted (car was a year old at this time), didn't line up so the body shop guy mixed in a tiny bit of blue.
Old Mar 14, 2004
XenonCiv01's Avatar
XenonCiv01 is an unknown quantity at this point
best thing to do would let a body shop handle it.
Old Mar 14, 2004
skiboard's Avatar
my side didnt fit either, so I had to sand down inside of the side skirt to make it fit. it's kinda paper thin now which might break easily.but that might be only choice you can take if you are going to handle it. and you might need to re drill holes for screws
Old Mar 14, 2004
slicksivik's Avatar
i got xenon side skirts and i put them on myself. I jacked the car up. Took the tires off. The i put the red automotive 3m tape on it, then added some water resistant epoxy ontop of that. Then i just slide it on. For fittin tho, you would have to first take it and try to fit it, if the holes dont line up on the sides, no big whoop, didn't for me, i just took a drill and a thin drill and drill through where i needed the hole and then screwed the screw through the rest of the way and it works fine. If its not long enough, then maybe u should lower it down on the car. Make sure its on the bottom part of the side, not higher or it wontfit.
Old Mar 14, 2004
What are you talking about slicksivik with the bottom, not higher or it won't fit?
Old Mar 14, 2004
import2nr's Avatar
awd pwnz j00
he means if the skirt isnt sitting in the right spot (too high up) it wont fit. because the side of the car gets wider as you go up
Old Mar 14, 2004
I just tried test fitting again today, and for some reason everything seemed to fit fine. Thanks for the info everyone, off to paint it goes tomarrow. I'll let everyone know how it goes.
Old Mar 15, 2004
dru106's Avatar
ThE CoRRupToR
yeah i had the same problem. I was like ****!! I just got it painted and now it wont fit.....WTF!!! I was pissed till my friend helped me out and forced it in there and kinda cut the bumper
Old Mar 15, 2004
kTxCiN's Avatar
Stage7
kTxCiN is an unknown quantity at this point
most of the time one of the best ways to get sides to fit is the body shop will cut them in half, and re fiberglass them =/
Old Mar 15, 2004
Well everything is fine now, I'm just waiting for the kit to come back from painting. Does anyone know if autozone rents the larger car jacks that jack up either the entire front end or the entire rear? How did everyone else jack up their cars to put on their side skirts?
Old Mar 15, 2004
acidbaby's Avatar
The Beez Kneez
buy from a good seller next time!
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
Youshoe
May 22, 2015 09:36 PM
aZnVoYCe
Dec 7, 2001 12:41 AM
aZnVoYCe
Nov 7, 2001 05:54 PM
