Sponsored by:
Sponsored by: CARiD
tsunami front bumper need help please
Old Mar 12, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Question tsunami front bumper need help please
ok guys i just got my tsunami front bumper and im thinking of trying to get the holes done for it tomorrow i need to know what i should do. do i just take a drill bit and drill out all the holes that are in it on the little dimple marks and they should match up or what should i do?
and second, what do i do to make the little cuts in the side that snap into place should i use my dremel tool and cut them and if so how do i mark them?
also if it doesnt fit just right how can i fix it.
thanks for the help guys
Old Mar 12, 2004
slicksivik's Avatar
just line it up and drill
Old Mar 12, 2004
oh and also should i line everything up fit it and then cut the slots in the sides?
Old Mar 12, 2004
come on guys i really need some help here does anybody know about fitting this thing and yes i did search and read what i could, but i need more help ive never even seen anything like this done before so im going trial and hopefully no error here.
Old Mar 12, 2004
JayFReaZy's Avatar
I used a drill and a box cutter. No, the bumper will not fit 100% exactly snug. So, dont worry if its kinda saggy or has a problem fitting into the headlights (like mine). Just go and put it on during a nice day in the morning, so you have the whoooleee day to work on it. You'll be fine. Also, try and get someone else to help you, it'll make things a hell of a lot easier. Good luck!
Old Mar 13, 2004
should i put it on first and then try and fit it and then cut the holes
Old Mar 13, 2004
JayFReaZy's Avatar
what do you mean test it on first? The way I did it was I cut the 3 holes near the wheel whell on the side of the bumper, then I cut the holes for the pushpins where the grill is at, then I drilled the holes for where the screw goes in the wheel well. Cut the hole first, then paint it, then install it. You dont have to test fit it, it will fit, with a little effort.
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
SpecialRequest
Jul 7, 2015 07:52 PM
