Sponsored by:
Sponsored by: CARiD
HID Bulbs
Old Sep 26, 2003
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
HID Bulbs
If I got a 6000k kit, and I wanted to put 8000k bulbs in... would it do any damage to my kit? Help me out guys...
Old Sep 27, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
as long as the ballasts are compatiable (sp?)
but why would you want to go with 8000K??
Old Sep 27, 2003
vietfob714's Avatar
i got a really cheap 9007 kit from a friend.. so i tried customizing them to fit... they fit fine but lets just say i can see stop signs and trees a lot clearer then i can see the road... so i gotta buy h4 bulbs... i know theres a lil color difference btw the 6000 and 8000 ... is there any other differences?
Old Sep 27, 2003
streetglower's Avatar
I have a 8000k kit on my car and the only differences from it and a 6000k kit is the color. The 6000k kit is more white, while the 8000k kit is more purple/blue. I saw the 6000k kit on a customized integra. As with putting 8000k bulbs in a 6000k kit, it might not be a good idea because the ballast with the kit will only support the 6000k bulbs, it might burn up the kit with the 8000k bulbs, I really dont know for sure on that though.
Old Sep 27, 2003
speedracersong's Avatar
from what i hear you can just swap out bulbs just fine.
umm putting in 8k bulbs is just wasted light. they look cool as hell cause its all blue but bad visibility. i have a 5k kit and its white with a slight blue tint.
Old Sep 27, 2003
duyaknow's Avatar
duyaknow is an unknown quantity at this point
The purple is because of the glass projector lens. It causes the white light to bend at certain angles, which causes the purple appearance, but only at certain angles. If you get the 8000K kit, it will be purple blue all the time. Completely different IMO. I'd stick with the 6000K, so you won't get much cop attention.
Old Sep 27, 2003
With my 8000k kit, I can see just perfectly, and have perfect visibility, and the color is awesome. It honestly compares to OEM HID kits with brightness, but better color.
Old Sep 28, 2003
Hefe's Avatar
I highly doubt that...
Old Sep 28, 2003
you highly doubt what?
Old Sep 28, 2003
Hefe's Avatar
that it compares to OEM brightness... you may have the "look" of OEM brigthness... but not the actual visiblity of OEM..
Old Sep 28, 2003
the second night that I had the HIDs I was at a light with a s2000. When there headlights beam off the ground, it resembles the color of stock halogen headlights, when my hit the ground it is pure white with a hint of purple. When I compared the distance they were both about the same. My kit is bright as hell, if you dont believe me I will drive up to San Antonio and show you.
Old Sep 28, 2003
Hefe's Avatar
ok.
Old Sep 28, 2003
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
I have an 8000K kit myself, and I agree with street .. the 8K is NICE. I like the deep blue color, and I can see great at night with them. Actually I have a bulb out that I'm waiting to get replaced, and I'm still putting out just as much light, maybe even more, than people with 2 haolgen bulbs. I love it ...
FYI The 6000K does have a little better light output though, because it's whiter, but I wanted more blue color to mine so I went for the 8K ...
Scale:
2-3K = Standard halogen (Blech)
4-5K = Bright White
6K = Super Bright White, Bluish tint
8K = Bright Blue
10K = Purple
Old Sep 29, 2003
I knew there was someone out there that had a 8000k kit and knew that it was bright as hell, I think they look better than lower HID kits. Also if you look at a car with a OEM HID kit and look at the ground in front of it when it is driving or parked, you will notice that it reflects the color of halogen bulbs, mine reflects a whitish, purplish tint, looks so much better.
Old Sep 29, 2003
Hefe's Avatar
StreetGlower.. What HID kit do you have again?
Old Sep 29, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
ne one know where we can buy the reflector housings? to aim the beams better?
Old Sep 29, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Question Where to get??
Hey guys,
Since you are all talking about HID kits right now...Where is a good place to still get them with all the legal issues going on and all. Are they still obtainable from some places? Or are they impossible to get?
Also I have projectors in my car (take a look at my ride to see which ones), and was wondering with modification, would the HID kit fit?
Old Sep 29, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
GB section.. vender in NY is selling them for the low low.
Old Sep 29, 2003
Hefe's Avatar
unless you put on aftermarket headlight housings (i.e. projectors) the car comes standard with reflector housings..
Old Sep 29, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea but they're not made for HIDS
Old Sep 29, 2003
I have a Super Vision 8000K kit.
Old Sep 29, 2003
ImPulse's Avatar
Id like to know if H1 HID bulbs can work off the H4 HID ballasts & wiring... anyone?
Old Sep 29, 2003
ImPulse's Avatar
http://globalpremier.com
Old Sep 30, 2003
BlueFlame's Avatar
Yeah, you just have to split the wiring. H4 has 3 wires, 1 positive low-beam, 1 positive high-beam, and 1 ground. Figure out which is the low beam positive and connect it with the positive in on the HID bulb. Then do the same with the ground wire and it should work. You'll probably have to splice your ground wire though, since you need 1 for low and 1 for high.
However, after re-reading your post, I don't know about the wiring for the ballasts. I'm pretty certain they won't, since H4 is a dual bulb (low and high beams) and H1 is a single. So my answer woud be probably not in that case. The voltage would be off as well if I'm not mistaken
Old Sep 30, 2003
ImPulse's Avatar
the h4's i have are only single beam.. not dual
so there are no highs... So it should work?
Old Sep 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
thats not true at all... both bulb styles come in HIGH AND LOW.. .and both come in just low...
and thats not true about the wiring... its 1 positive and one ground, with an ALTERNATING Ground and Positive on the 3rd wire
Jay- in order to use an H1 bulb on ur HID's u need to get a bulb that matches the valtage on ur bulbs now. other problem will be the connector... the h1 and h4 bulbs connect different ways.
i highly doubt u can do it.
Old Sep 30, 2003
ImPulse's Avatar
w/e wont have HIDs... Im gonna get projectors wit stock bulbs (Back to regular light =\)
Old Sep 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
im gonna laugh at you jay cause u cant see **** with projectors.. i used to have them.. so when it rains out.. and ur bitching that u cant see... I dont even come near me cause im gonna laugh my *** off
Old Oct 1, 2003
those arent the HIDs that I have, I actually have the thin bulbs, the actual HID bulbs.
UltraHDGames
Jun 8, 2016 05:16 PM
cferry7
Oct 18, 2015 06:32 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
