Sponsored by:
Sponsored by: CARiD
Apexi V-AFC II
Old Sep 14, 2003
ImportRacer2123's Avatar
K20 Member
Apexi V-AFC II
Did anyone buy the V-AFC II? if so is it better than the 1st one? Because for some reason i have my V-AFC hooked up just fine no problems no check engine lights nothing. Just curious if it is worth it to swap on over to V-AFC II.
Old Sep 14, 2003
streetglower's Avatar
what does the V-AFC II do?
Old Sep 14, 2003
onebuddha1's Avatar
onebuddha1 is an unknown quantity at this point
i bought tha vafc2 and installed it last week... install was easy but took awhile becuz i want to check and recheck tha wires i was splicing/cutting... i dont know what tha first gen is like... but i have read alot about them..... i havent had ne problems but i also havent had a chance to dyno it.. i have messed with tha settings a little.... but not much..... i feel like im working blind without a dyno..... but for $320 i thought it was a deal so i bought it quick
Old Sep 14, 2003
onebuddha1's Avatar
btw.... it
"The A'PEXi VAFC 2 is the sequel the the infamous VAFC, the digital fuel controller that allows optimal fuel enrichment and VTEC engagement control. Corrections can be made according to throttle position and includes parameters for both low and high camshaft lobes. This is what is required to change VTEC engagement points without damaging your engine. The new VAFC 2 works with VTEC and i-VTEC engines and has an illuminated dial that changes color with vtec engages. " - inlinefour.com
Old Sep 14, 2003
damn I didnt really understand any of that, explain it to me differently and why it is a good product to buy.
Old Sep 14, 2003
HondaLuver's Avatar
Its a celebration bitches!
so... no check engine light?
Old Sep 14, 2003
onebuddha1's Avatar
no check engine light... i drove it this morning purposly to drive in tha cold.... bout 50 degrees F... i did not cut out at 4,000 RPM... are there ne other things i should try out? let me know
tha vafc2 is a vtec controller/ air fuel converter.. you can change ur vtec engagement point to kick in when you want.. after you change ur point.. you can correct ur air/fuel curve to send tha right amount of air/fuel to maximize ur engines performance.. i say buy it.. i luv it... and i havent dynoed it yet....
Old Sep 14, 2003
civic01vtec's Avatar
where did u buy it from ?
Old Sep 14, 2003
onebuddha1's Avatar
www.inlinefour.com a shop in wesminster,ca
Old Sep 14, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
That's good to hear!!! I just ordeered my JDM VAFC II (Silver) from Ebay...I got a good deal for $285...I'm going to sell my Vafc I to my friend with a Integra GSR.
Old Sep 14, 2003
cwick187's Avatar
I can't seem to find the wiring diagram for our cars anymore...Does anyone have it??? PM me you do
cukaracha
Aug 27, 2015 02:02 AM
Theshwartz35
Jul 17, 2015 11:13 PM
HondaLuver
Aug 9, 2002 07:52 PM
NeoMagus
Mid Atlantic
Apr 24, 2002 12:14 AM
myexownsyou
Apr 10, 2002 01:15 PM
