No power at all again
Old Feb 5, 2019
DeadCivic's Avatar
DeadCivic is an unknown quantity at this point
This is an ongoing problem. Battery dead. I jump start the battery and take my car to the auto parts store around me. The person was checking the voltage of things and told me my alternator was bad. I replaced the alternator and then got a brand new battery because it was under warranty. I drove the car for a day and now my car is completely dead again. I turn the key and there’s no lights. Nothing. I visually inspected the 100amp fuse and it doesn’t look blown. The terminals don’t have any corrosion and appear to be in good shape. The car has 60k miles on it but it’s 13 years old. 2006 Civic LX
One thing I did last night before I had any repeated battery problems, I disconnected the battery to put on those red and black anti corrosion rings because I forgot to get them from off old battery. I took the terminals off negative first, then positive. The terminals never touched anything. After I hooked the battery back up, I drove my car to the store and back then back home like normal. Now this morning my car is dead. Where do I go from here?
Old Feb 5, 2019
mac25's Avatar
Dr Krieger of Modification
Re: No power at all again
First isolate if it is an initial battery/alternator starting issue (even though they are new). If it starts by jumper cable you know the other systems are working (fuses, relays, power ground, ecu).
That will leave you with either a parasitic lose where a system is draining the battery overnight, a bad alternator, bad battery, or loose alternator belt.
If while hooked up to jumper cables/starter pack, it does not start then listen for the starter. If no starter, test that circuit first, then replace the starter as needed.
If the Battery, alternator, and starter are good, then you'll be down to relays/fuses/wiring/ecu or parasitic lose.
Good luck.
artbesch
Aug 16, 2016 07:07 AM
Skunkone
Sep 24, 2015 04:38 PM
thewal
40
Jan 31, 2013 01:05 PM
tjbarker
Aug 16, 2010 02:23 PM
Dizzymofo
Apr 18, 2004 02:31 PM
