Wiring 8th gen horn plug to a Nrg short hub
I am trying to hook up my stock harness from the oem wheel to my nrg short hub in order to only access the horn, I have a MOMO tuner steering, but issue is with the massive amount of wires coming out of the plug, does anyone have a diagram labeling the horn wiring only, or any helpful advice at all?
Re: Wiring 8th gen horn plug to a Nrg short hub
On the OEM wheel there is a single black wire that runs to the airbag side of the push switch. When the airbag side of the switch is pushed down the with your hand on the oem logo/airbag/horn, it contacts the oposit side of the switch.
Put the wheel back to stock and identify the two wires which form the switch.
boxinggsxr
Jan 11, 2013 12:40 AM
StealthCivic
Mar 5, 2006 05:44 PM
![[HOONDA] is an unknown quantity at this point](https://www.civicforums.com/forums/images/reputation/reputation_balance.gif)
