Battery drain
Old Jul 29, 2018
Lock's Avatar
Lock is an unknown quantity at this point
Battery drain
Hi
so here is the deal . My sons 2006 civic has been draining the battery. I tried the AC relay and not that . New battery and altanater still not the problem .
I took it to the shop again the other day the tech looked under the dash and noticed one of those cheap code readers plugged in and just pushed under the dash . It seems that this is the problem . If I unplug it the car does not drain the battery.
Here is the problem when I unplug it the car turns over but Will Not start .
Any suggestions would be great .
***Personal information removed by Admin***
Thanks in advance .
Last edited by xRiCeBoYx; Jul 29, 2018 at 02:03 PM. Reason: Personal contact information removed by Admin
Old Jul 29, 2018
GolNat's Avatar
Prelude Owner
Re: Battery drain
Maybe it's not a code reader but some type of bypass for something.
Did you Google what it is?
Old Jul 29, 2018
Lock's Avatar
Re: Battery drain
Going to do that now .
Old Jul 29, 2018
Re: Battery drain
It's probably lost a ground. The code reader plug is bridging the two ground terminals in the OBD2 connector, and one of those is extremely important for the computer and engine controls.
https://www.justanswer.com/honda/8o9...automatic.html <--CLICKY LINK
erics
16
Dec 24, 2020 06:38 AM
r3load
Electrical
Jun 16, 2020 09:59 AM
gearbox
35
Aug 31, 2015 10:09 PM
Pete6032
Jan 5, 2015 06:50 PM
nunzio42
Jul 20, 2003 10:40 AM
