ELD malfunction affect battery power?
Old Jan 5, 2015
Pete6032's Avatar
Pete6032 is an unknown quantity at this point
I took my car in for an oil change and the mechanic told me my battery was low. I know I've got a p1298 electric load detector code and I need to fix the ELD but haven't gotten around to it. Would this possibly be affecting the battery readings that the garage did when I got my oil changed?
Also will disconnecting the negative battery terminal reset the OBD so after I've replaced the ELD I will no longer get the code?
Old Jan 5, 2015
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
Re: ELD malfunction affect battery power?
No, they probably tried to turn your car on and noticed they had to crank the crap out of it so they put a voltmeter on the battery terminals. How old is the battery? Original?! If you want to check your own battery, get out a volt meter and check it yourself to be sure, but it usually does not last more than 5 years.
No need to disconnect the battery to clear the CEL, just pull fuse #6 for 10 seconds and reinsert.
There is a Honda TSB out for your car and the code. Shows you how to replace the part. Here it is:
http://goo.gl/R51FjD
Old Jan 5, 2015
Pete6032's Avatar
Thanks. The battery is from 2010, Honda battery, so I will go to the dealer I guess and try and get a portion of the warranty toward a new one.
h4ldol
Jun 3, 2015 03:26 PM
MiniMi
May 27, 2015 01:57 PM
tylerginevan
Apr 27, 2015 12:29 PM
tattedlariat
Apr 20, 2015 09:26 PM
SSMatey
Apr 13, 2015 06:09 PM
