Bluetooth not displaying
I have a 2013 Civic LX Coupe. The Bluetooth display will not open in the display window when either the "Phone" button on the radio console or the steering column are depressed. All other functions work and display just fine. Has anyone else seen this problem and is there an easy fix?
Re: Bluetooth not displaying
3 buttons on the steering wheel, do they do anything at all?
Center button on the steering wheel set, hold it in for 10 seconds, does the handsfree give you a verbal test message?
.........In the shop, my first instinct would be to search around for another compatible car, make sure the HFL (handsfreelink, bluetooth) in that car does work, then remove and swap the suspected dead HFL control unit into the working car, see if the one from the bad car still doesn't work in the good car..... verify the unit is dead.
Or swap the other way, make sure a good unit works in the bad car.
If you want to go by the book, you'll need some good service information..... there's a whole bunch of wiring voltage and continuity checks to be done between the HFL unit and the radio, buttons, etc. and the terminals in the connectors are extremely small and very easy to damage if you don't have the correct size probes.
Ended up taking the car to a Honda dealer. As it turns out the previous owner had an aftermarket Bluetooth installed, possibly because the factory unit stopped functioning. The mechanic told me the factory units setting has been turned off and was reluctant to turn it back on due to not knowing why the aftermarket unit was install. Could not find a switch for turning the aftermarket unit on or off and guessing it does not come on automatically when the vehicle is turned on because my phone can't find any Bluetooth devices. So I'm just going to live without it. Thanks for your assistance.
If the aftermarket unit is still present, you could look up the unit (brand, any numbers you can find on its control unit) on the internet and get more info about using it and maybe some install instructions so you can find where inline fuses may have been pulled to disable it.
See if the original HFL control unit was unplugged (I wasn't aware of a way to just 'turn it off') maybe you can reconnect and have it work again?
IIRC that one may be above the glovebox.
alee.bsw
Oct 25, 2015 12:12 PM
Thedodger03
Oct 20, 2015 04:09 PM
fordfocussucks
Jan 25, 2002 09:04 AM
guy
Jan 6, 2002 04:39 PM
nymbus2k
Nov 11, 2001 08:53 PM
