Headlight is fogged.. Replace it? if so, need advice plz.
Old Nov 22, 2010
JosephWatts's Avatar
JosephWatts is an unknown quantity at this point
Hey all, I've run into a bit of a problem and would appreciate any feedback from the community..
Upon entering my garage, the headlight of my 09 Honda Civic EX (Automatic Trans) appeared to me to be opaque. Taking a closer look at the assembly, I noticed a tiny fracture running vertically from the base of the light.. Could this crack have allowed moisture to enter the assembly and cause it to fog up? Is replacing the assembly my only option, or can I somehow eliminatIe the fogginess and seal up the crack to restore it to its original beauty ?
While I don't want to jump to conclusions, I'm assuming that I'll just have to replace the light.. In this case, I've done some research on some online vendors that I found to like, but before I spend my money there I want to be sure they're legitimate businesses.
Either
http://www.autolightcenter.com/honda...s.html#MzkzNDk
or
http://vehicle-interior-parts.amazon...source=froogle
Forgive me for the long post/many questions, I feel like an amateur car owner sometimes : P But thanks in advance.
Old Nov 22, 2010
sam68's Avatar
sam68 is an unknown quantity at this point
Re: Headlight is fogged.. Replace it? if so, need advice plz.
Yes it could and probably did let moisture in, I would replace the entire light if it were my car. Those lights are probably not OEM if you want OEM try Majestic Honda they sell Honda parts cheap your local Honda dealer may also price match if you print it out and take it to them, my local dealer does.
Old Nov 22, 2010
Kennykid2002's Avatar
Kenny the Ricer
Well, your best bet is to replace it
But for a temporary solution, take apart your headlight housing, apply a bead of clear silicone caulk inside the crack, it it dry completely, and put the headlight back on
Another way i believe is to buy glass resin and fill the crack
Old Nov 23, 2010
09 or 01?
Old Nov 29, 2010
Paul79UF's Avatar
Paul79UF is an unknown quantity at this point
You could also get a generic replacement headlight assembly on eBay.
I bought some for my oldest car a few years ago and they still look good. Plus you can always buff out any haziness from the lens.
Old Nov 30, 2010
BlueEM2's Avatar
Whachya lookin at?
Replace it. You can try sealing the crack with clear silicone but I don't think you will ever get a proper seal. If your going to replace it, I suggest sticking with OEM.
Majestic Honda has them for 188 dollars: Linky:
http://www.hondaautomotiveparts.com/...gry5=HEADLIGHT
^ That's for a coupe btw. I don't know with 8th gens if the headlights are the same for coupe or sedan so make sure you go through the selection process and pick the right one.
Depending on your miles I'd try to get it replaced as warranty item, you never know they may just do it
Last edited by BlueEM2; Nov 30, 2010 at 05:54 AM. Reason: Added some jibberish at the end
cukaracha
May 16, 2015 07:36 PM
intensity
May 12, 2015 10:43 PM
Jigee
May 9, 2015 11:18 AM
thesushiboy
Apr 12, 2015 02:54 AM
SWEETRIDE
Nov 27, 2001 05:52 PM
