o6 Civic Coupe LEDs
Old May 16, 2010
_S_'s Avatar
_S_
_S_ is an unknown quantity at this point
o6 Civic Coupe LEDs
I am trying to install LED bars that turn on when the car is unlocked, tapped into the Dome light. However, after spending two hours messing with the electronics, I'm baffled. Using a wire tester, with Red grounded, I tested the dome light and found that it had continuous power. I was hoping to be able to attach these LEDs without a switch. Am I doing something wrong?
Old May 16, 2010
CraigW's Avatar
Re: o6 Civic Coupe LEDs
1 side of the circuit is constant 12 volts and the other side is a ground that is provided by the MICU inside the under dash fuse box.
You will have to determine the polarity needed to light the LEDs. it should work fine.
What color wires did you tap into ??
Old May 16, 2010
_S_'s Avatar
_S_
I tapped directly into the dome light wires; they are blue and pink with grey stripes.
Old May 16, 2010
CraigW's Avatar
Just use those 2 wires to power the LEDs, do you have red & black leads on the LEDs ??
Your red will go to the line with constant power (can't remember which, pink iirc) and the ground will be provided from the other line to the black lead on the LEDs and they should light when the dome light does.
Old May 16, 2010
_S_'s Avatar
_S_
I wired it exactly like that; however, the LEDs just remain lit.
Old May 16, 2010
CraigW's Avatar
Does the dome light still work correctly ??
Also make sure the dome switch is not set to "ON"
Poopies
Apr 20, 2017 11:36 PM
miatabro
Jul 17, 2015 12:12 PM
oneheadlight
Apr 29, 2015 11:30 PM
shaejb15
Apr 26, 2015 07:44 PM
CapYoda
Nov 11, 2001 05:17 PM
