unknown leak
Old Feb 3, 2020
ytaki510's Avatar
ytaki510 is an unknown quantity at this point
unknown leak
Hi, I am experiencing a leak and I'm not sure where its coming from.
This is right next to the front passenger side tire, it doesn't smell like anything so I'm guessing it's water, haven't used the A/C in a while so I don't think its that either.
Any help/suggestions would be greatly appreciated.
Old Feb 3, 2020
GolNat's Avatar
Prelude Owner
Re: unknown leak
Have you used the defroster? It turns the AC on even if on full heat.
Old Feb 3, 2020
ytaki510's Avatar
Re: unknown leak
I probably turned it on a few times, I didn't know that hot air can cause the leak as well, thought only blasting the cold air causes condensation to form. Thank you!
Old Feb 3, 2020
GolNat's Avatar
Prelude Owner
Re: unknown leak
When you use defrost it turns the AC compressor on so that it can remove the humidity out of the air and help the window defrost faster.
f you want you could wipe it all down and then check it again in a few days. If it has so smell then it's not coolant and if it feels like water it is not oil.
bashea
Sep 14, 2018 03:22 PM
93honda
Sep 6, 2012 08:19 PM
Nealmend
May 10, 2012 01:59 PM
damoore
15
Feb 13, 2012 12:56 AM
